[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Tue Aug 13 09:16:44 PDT 2013
What if there happens to be empty/null geometries in your source data? I guess you can add "AND geometry in not NULL" and perhaps even "AND IsValid(geometry)=1" to your DATA line.
-Jukka Rahkonen-
Andrea Peri wrote:
> I'm using spatialite 4.1.1,
> so use ogr to access the db.
LAYER
NAME "rt_topogr.50k.etichette.topon_idro_50k"
STATUS OFF
EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
TYPE LINE
CONNECTIONTYPE OGR
CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
PROJECTION
"+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
END
METADATA
"wms_title" "topon_idro_50k"
"wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
END
LABELCACHE ON
MAXSCALEDENOM 60100
MINSCALEDENOM 1
CLASS
NAME ''
MAXSCALEDENOM 60100
MINSCALEDENOM 1
LABEL
TEXT '[TOPO_OK]'
COLOR 0 85 255
OUTLINECOLOR 212 255 255
OUTLINEWIDTH 1
MAXSCALEDENOM 60100
MINSCALEDENOM 40100
FONT "LiberationSans-Regular"
TYPE truetype
SIZE 7
ANGLE FOLLOW
OFFSET 15 99
POSITION auto
PRIORITY 10
MAXOVERLAPANGLE 180.0
BUFFER 1
FORCE OFF
PARTIALS FALSE
MINDISTANCE 200
END
LABEL
TEXT '[TOPO_OK]'
COLOR 0 85 255
OUTLINEWIDTH 1
MAXSCALEDENOM 40100
MINSCALEDENOM 1
TYPE truetype
SIZE 9
ANGLE FOLLOW
OFFSET 15 99
POSITION auto
PRIORITY 10
BUFFER 1
FORCE OFF
PARTIALS FALSE
MINDISTANCE 200
END
END
END
2013/8/13 thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>>
there's something strange in your error message... the
singleSidedBuffer stuff is in GEOS, and should have nothing to do in
msOGRFileNextShape. post your whole mapfile layer.
On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com<mailto:aperi2007 at gmail.com>> wrote:
> Hi,
> I tested trasforming the multilinestring dataset in a linestring dataset but
> the error is still here.
> msDrawMap(): Image handling error. Failed to draw layer named
> 'rt_topogr.50k.etichette.topon_idro_50k'.
> msOGRFileNextShape(): OGR error. IllegalArgumentException:
> BufferBuilder::bufferLineSingleSided only accept linestrings
> So it is not really due to a multilinestring vs linestring question.
> The quest carry on.
> 2013/8/13 Andrea Peri <aperi2007 at gmail.com<mailto:aperi2007 at gmail.com>>
>> Hi,
>> Try.ing to set a label on a MULTILINESTRING dataset.
>> I set a label with Follow capability.
>> ANGLE FOLLOW
>> But I'm having this error:
>> Is the Follow compatible with a MultiLinestring dataset or need only
>> simple linestrings ?
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Andrea Peri
qwerty àèìòù
