[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 13 09:17:39 PDT 2013
why the double label? they seem to be the same, but in any case
multiple labels are not supported for FOLLOW.
On 13 August 2013 18:08, Andrea Peri <aperi2007 at gmail.com> wrote:
> I'm using spatialite 4.1.1,
> so use ogr to access the db.
> LAYER
> NAME "rt_topogr.50k.etichette.topon_idro_50k"
> STATUS OFF
> EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
> TYPE LINE
> CONNECTIONTYPE OGR
> CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
> DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
> PROJECTION
> "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
> END
> METADATA
> "wms_title" "topon_idro_50k"
> "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
> END
> LABELCACHE ON
> MAXSCALEDENOM 60100
> MINSCALEDENOM 1
> CLASS
> NAME ''
> MAXSCALEDENOM 60100
> MINSCALEDENOM 1
> LABEL
> TEXT '[TOPO_OK]'
> COLOR 0 85 255
> OUTLINECOLOR 212 255 255
> OUTLINEWIDTH 1
> MAXSCALEDENOM 60100
> MINSCALEDENOM 40100
> FONT "LiberationSans-Regular"
> TYPE truetype
> SIZE 7
> ANGLE FOLLOW
> OFFSET 15 99
> POSITION auto
> PRIORITY 10
> MAXOVERLAPANGLE 180.0
> BUFFER 1
> FORCE OFF
> PARTIALS FALSE
> MINDISTANCE 200
> END
> LABEL
> TEXT '[TOPO_OK]'
> COLOR 0 85 255
> OUTLINEWIDTH 1
> MAXSCALEDENOM 40100
> MINSCALEDENOM 1
> TYPE truetype
> SIZE 9
> ANGLE FOLLOW
> OFFSET 15 99
> POSITION auto
> PRIORITY 10
> BUFFER 1
> FORCE OFF
> PARTIALS FALSE
> MINDISTANCE 200
> END
> END
> END
> 2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
>> there's something strange in your error message... the
>> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
>> msOGRFileNextShape. post your whole mapfile layer.
>> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > Hi,
>> > I tested trasforming the multilinestring dataset in a linestring dataset
>> > but
>> > the error is still here.
>> > msDrawMap(): Image handling error. Failed to draw layer named
>> > 'rt_topogr.50k.etichette.topon_idro_50k'.
>> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
>> > BufferBuilder::bufferLineSingleSided only accept linestrings
>> > So it is not really due to a multilinestring vs linestring question.
>> > The quest carry on.
>> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com>
>> >> Hi,
>> >> Try.ing to set a label on a MULTILINESTRING dataset.
>> >> I set a label with Follow capability.
>> >> ANGLE FOLLOW
>> >> But I'm having this error:
>> >> Is the Follow compatible with a MultiLinestring dataset or need only
>> >> simple linestrings ?
>> >> Thx,
>> >> Andrea Peri
>> >> qwerty àèìòù
>> > Andrea Peri
>> > qwerty àèìòù
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
