[mapserver-users] cgi variable substituition in DATA statement
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Wed Aug 21 14:21:55 PDT 2013
Sorry, I hit enter by accident.
Meaning was to suggest to try what happens if you use
AND (((acquisition_date >= date_trunc('day',date %STARTDATE%)
in the DATA line and include single quotes in the STARTDATE string. Perhaps SQL interpreter thinks now that %STARTDATE% between single quotes should be taken literally with the per cents signs.
-Jukka Rahkonen-
________________________________________
Rahkonen Jukka wrote:
Blind guess, but perhaps quetes inside the SQL of you DATA leads to unexpected result
AND (((acquisition_date >= date_trunc('day',date '%STARTDATE%')
Make a try to write this as
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Peter Freimuth [freimuth69 at gmail.com] puolesta
Lähetetty: 21. elokuuta 2013 20:43
Vastaanottaja: thomas bonfort; mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] cgi variable substituition in DATA statement
Hi Thomas,
thanks for the hints. I compiled 6.4beta2 this morning and applied the
proposed changes but the behaviour keeps the same.
The substitution is just not done.
I changed the VALIDATION block on map and layer level to below and also
using now DATAPATTERN '.*' on map level.
VALIDATION
#'PRODUCTID' '^[a-zA-Z0-9\-\_\,]+$'
#'CONTRACTIDS' '^[a-zA-Z0-9\-\_\,]+$'
#'STARTDATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
#'ENDDATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
'PRODUCTID' '.*'
'CONTRACTIDS' '.*'
'STARTDATE' '.*'
'ENDDATE' '.*'
'default_PRODUCTID' '1234567'
'default_CONTRACTIDS' 'GDNAMLI-USA-MT'
'default_STARTDATE' '2011-01-01'
'default_ENDDATE' '2013-09-01'
END
It seems that the mechanismn is not working at all and i cannot find
anything in the logs even with debug level 5.
Any further idea?
Thanks,
Peter
On 20/08/2013 5:35 PM, thomas bonfort wrote:
> try setting your VALIDATIONs to '.*' to see if your problem lies in
> your regex or elsewhere. For 6.3/4 You can also remove your
> xxx_validation_pattern metadata entries, and should move the
> default_xxx ones into the VALIDATION block.
> thomas
> On 21 August 2013 01:26, Peter Freimuth <freimuth69 at gmail.com> wrote:
>> Hi,
>> i am trying to get the dynamic variable substitution work on Mapserver
>> 6.3dev but somehow it does'nt work as it worked before and as documented.
>> When i execute
>> http://10.10.4.18/cgi-bin/LI_USA-MT.cgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=48.046271,-115.929840,48.198407,-115.666914&CRS=EPSG:4326&WIDTH=1647&HEIGHT=953&LAYERS=data_view&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=TRUE&STARTDATE=2011-01-01&ENDDATE=2013-09-01
>> or
>> I get an error in
>> msDrawMap(): Image handling error. Failed to draw layer named 'data_view'.
>> msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
>> invalid input syntax for type date: "%STARTDATE%"
>> LINE 8: ... (((acquisition_date >= date_trunc('day',date '%STARTDAT...
>> So the substitution does not happen or the default is not applied.
>> Any hint on what i am doing wrong would be great.
>> See below the components from the mapfile:
>> MAP
>> # Start of web interface definition
>> DATAPATTERN '^[a-zA-Z0-9\-\_\,]+$'
>> WEB
>> IMAGEPATH "/mnt/mapserver/mapserver_wms/geocloud_config/image_path"
>> METADATA
>> 'PRODUCTID_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
>> 'CONTRACTIDS_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
>> 'default_CONTRACT_IDS' '0000'
>> 'STARTDATE_validation_pattern'
>> 'ENDDATE_validation_pattern'
>> 'default_END_DATE' '2013-09-01'
>> END
>> VALIDATION
>> END
>> END
>> LAYER
>> # this is the tileindex that aggregates the single image products
>> together and makes them accessible for the RASTER LAYER "data_view" and
>> "data_raw" for rendering
>> NAME "data_idx"
>> STATUS ON
>> DEBUG 5
>> UNITS dd
>> TYPE POLYGON
>> EXTENT -116.364631680367 44.1932837062986 -103.698350095065
>> 49.1892799088128
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "user=***** password=***** dbname=***** host='*****'
>> port=5432"
>> DATA "wkb_geom FROM (SELECT t1.* FROM (SELECT re3aip.cat_id as
>> archived_in_archiving_identifier, ico.image_id, ico.acquisition_date,
>> re3aip.tile_id,
>> ico.product_provider_image_identifier, re3aip.ohs_order_id,
>> re3aip.imagetake_cat_id, ico.epsg_code,
>> re3aip.ohs_contract_id, ico.service_name,
>> ico.footprint_poly::geometry as wkb_geom, ico.image_location,
>> ico.vrt_location
>> FROM ows.imagepool_catalogue_ows ico
>> JOIN ows.re_l3a_imagepool re3aip ON (re3aip.image_id=ico.image_id)
>> WHERE ico.service_name in ('LI_USA-MT') AND
>> (((acquisition_date >= date_trunc('day',date '%STARTDATE%') AND
>> acquisition_date < date_trunc('day',date '%ENDDATE%') + interval '1 day')))
>> AND
>> re3aip.ohs_contract_id in ('%CONTRACTID%')
>> ) t1
>> LEFT OUTER JOIN
>> (SELECT ico.image_id, ico.acquisition_date, re3aip.tile_id
>> '%STARTDATE%') AND
>> AND
>> ) t2
>> ON
>> t1.tile_id = t2.tile_id AND
>> ((t1.acquisition_date < t2.acquisition_date) OR
>> (t1.acquisition_date = t2.acquisition_date AND t1.image_id < t2.image_id))
>> WHERE t2.tile_id is NULL
>> ORDER BY t1.ohs_contract_id, t1.tile_id
>> ) foo USING UNIQUE image_id USING
>> SRID=4326"
>> #FILTER ( '[product_provider_image_identifier]'='%PRODUCTID%')
>> PROJECTION
>> "init=epsg:4326"
>> END
>> METADATA
>> "ows_title" "Data Index"
>> "ows_extent" "-116.364631680367 44.1932837062986
>> -103.698350095065 49.1892799088128"
>> #'PRODUCTID_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
>> #'default_PRODUCTID' '1234567'
>> 'default_CONTRACTIDS' '0000'
>> #disable explicitly everything that shall not be supported for
>> this Layer
>> "wms_enable_request" "!GetCapabilities !GetMap
>> !GetLegendgraphic"
>> "wcs_enable_request" "!GetCapabilities !GetCoverage
>> !DescribeCoverage"
>> "wfs_enable_request" "!GetCapabilities !GetFeature
>> !DescribeFeatureType"
>> END
>> VALIDATION
>> 'CONTRACT_IDS' '^[a-zA-Z0-9\-\_\,]+$'
>> 'END_DATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
>> END
>> END
>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
