[mapserver-users] Mapserver 4.9
Daniel Morissette
dmorissette at mapgears.com
Tue Aug 27 12:47:52 PDT 2013
Note that 4.9 was never released, odd numbers are used to refer to the
state of the code during development leading to the next even number,
i.e. 4.9 was the dev version leading to the 4.10 release.
So it seems that FWTools was based on a snapshot of the source tree
sometimes between the 4.8 and the 4.10 release. You best bet may be to
use the 4.10 source, or otherwise you'll have to look for the exact date
or revision number of the source that was used to build FWTools and
extract that version of the source from the github repository.
Daniel
On 13-08-27 3:41 PM, Lime, Steve D (MNIT) wrote:
> All the old tarballs are at: http://download.osgeo.org/mapserver/. I
> can’t recommend using anything that old however.
> Steve
> *From:*mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of
> *Tara.Hemphill at l-3com.com
> *Sent:* Tuesday, August 27, 2013 2:34 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Mapserver 4.9
> Does anyone know where I can obtain the source code for Mapserver v4.9?
> There are branches 4.8 and 4.10 on github, but no 4.9. I am required to
> archive the source code since we use FWTools which comes with Mapserver.
> Mapserver v4.9 is the documented version in the FWTools 2.2.8 Readme file.
> Thank you,
> Tara H.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
