[mapserver-users] Orientation of vector symbols on a LINE
TC Haddad
tchaddad at gmail.com
Thu Aug 29 07:57:50 PDT 2013
Thanks Havard, for the pointer to the answer and explanation of the ratio
between SIZE and GAP. I feel like I will use that a lot.
Thanks Thomas for your clarification - my misunderstanding was regarding
the negative values, I hadn't fully internalized that y=0 was the top of
the symbol.
Tanya
On Thu, Aug 29, 2013 at 12:24 AM, thomas bonfort
<thomas.bonfort at gmail.com>wrote:
> Given that there's alot of undefined behavior with vector symbols, the
> documentation for anchorpoint is pretty clear about what is supported:
> <quote>
> ANCHORPOINT can be used with SYMBOLs of TYPE ellipse, pixmap, svg,
> truetype and vector. To ensure proper behaviour for vector symbols,
> the left and top edges of the bounding box of the symbol should be at
> 0.
> </quote>
> As a rule of thumb, VECTOR symbols are expected to work correctly if
> they respect that rule, i.e. your vector POINTS should have at least
> one point with x=0, at least one point with y=0, and no negative x's
> or y's.
> thomas
> On 29 August 2013 09:05, Havard Tveite <havard.tveite at umb.no> wrote:
> > The implementation of GAP has been fixed (center to center
> > distance between symbols), and so has the calculation of
> > symbol height.
> > I guess that the following should work:
> > STYLE
> > SYMBOL "wavy_line"
> > WIDTH 1
> > SIZE 2
> > GAP -6
> > COLOR 0 0 0
> > END
> > Since you have y values from -1 to 1, and x values between 0
> > and 6, the ratio between the height of your symbol and the
> > length is 2 / 6. The ratio between size and gap should be the
> > same to make the the line continuous.
> > Håvard
> > On 8/29/2013 1:31 AM, TC Haddad wrote:
> >> Hello, I'm trying to understand symbol orientation and (maybe) use of
> >> ANCHORPOINT on a line in Mapserver 6.2.
> >> The vector symbol that I have been using for line cartography in
> MapServer
> >> 6.0.3 is below, and I am trying to get the same effect in Mapserver
> 6.2.1.
> >> SYMBOL
> >> NAME "wavy_line"
> >> TYPE vector
> >> POINTS
> >> 0 0
> >> 1 1
> >> 2 1
> >> 3 0
> >> 4 -1
> >> 5 -1
> >> 6 0
> >> END
> >> END
> >> Display in Mapserver 6.0.3:
> >> https://dl.dropboxusercontent.com/u/42845001/mapserver6.0.3.png
> >> Relevant Style bloc from Mapserver 6.0.3:
> >> STYLE
> >> SYMBOL "wavy_line"
> >> WIDTH 1
> >> SIZE 2
> >> GAP -1
> >> COLOR 0 0 0
> >> END
> >> This did not translate directly to Mapserver 6.2.1, but I came close
> with
> >> this:
> >> STYLE
> >> SYMBOL "wavy_line"
> >> WIDTH 1
> >> SIZE 4
> >> GAP 6
> >> COLOR 0 0 0
> >> END
> >> which produced this:
> >> https://dl.dropboxusercontent.com/u/42845001/mapserver6.2.1.png
> >> Obviously I am missing something about how to get the symbol to orient
> >> along the line, I played with ANCHORPOINT as that was new in 6.2 and it
> >> seemed like the default of 0.5 0.5 should work for my symbol, but I
> also
> >> tried several other value combinations and it seemed to merely shift the
> >> symbol around laterally, while maintaining an upright orientation.
> >> So I'm a bit confused on how to achieve the original effect, (behavior
> >> something like the equivalent of FOLLOW for Labels). Any pointers
> >> appreciated...
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Håvard Tveite
> > Department of Mathematical Sciences and Technology, UMB
> > Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> > Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130829/54fa8cad/attachment.html>
