[mapserver-users] ms4w error Corrupt, empty or missing file (ECW)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Aug 30 09:23:52 PDT 2013
Hello Marco,
We removed ECW support from the MS4W suite back in 2009, due to
licensing restrictions. If you go to the MS4W issue tracker you can
research this in depth. However we do offer custom builds for ECW
support with MS4W, and you can contact me at any time if you require this.
Thanks again for using MS4W!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2013-08-30 11:42 AM, Marco Afonso wrote:
> Hi all,
> We are in transition from old ms 5.4 to new ms 6.0
> We have successfully installed ms4w 3.0.6 and everything is working as
> expected.
> The only problem is opening shapefiles with ECW.
> From logs this is the type of error:
> [Fri Aug 30 14:25:53 2013].460000 Corrupt, empty or missing file
> 'D:\ortos\ortos2010\005811Brgbx_10_d73.ecw' for layer 'ortos2010' ...
> ignoring this missing data.
> These shapefile is ok as it works with our previous version of maserver.
> They are not corrupt, empty or missing.
> All the paths are correct and set in the Apache httpd.conf (SetEnv
> directive)
> I did run ogrinfo on the shapefile and it seems ok, although I did not
> found ERDAS ECW format when running ogr2ogr --formats
> What can I do more o try to find the problem.
> All the best,
> Marco Afonso
