[mapserver-users] Rewarping/Reprojection with GDAL and -wo EXTRA_SOURCE parameter
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Tue Dec 17 08:57:38 PST 2013
Can you try if PROCESSING "POLYLINE_NO_CLIP=YES" helps on TYPE LINE layers?
> -----Ursprüngliche Nachricht-----
> Von: Heiko Schröter [mailto:schroete at iup.physik.uni-bremen.de]
> Gesendet: Dienstag, 17. Dezember 2013 16:46
> An: Eichner, Andreas - SID-NLKM; mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Rewarping/Reprojection with GDAL and -
> Thanks for the hint, but sorry no, does not change rewarping
> behaviour
> of POLYGON or LINE Layers.
> Distortion and missing parts do remain.
> The odd thing:
> The projection of all layers is ok if the BBOX equals or is greater
> than
> max extension of the map.
> i.e. BBOX=-6500000,-6500000,6500000,6500000 [proj=ortho units=m]
> By "zooming" in i.e. reducing the BBOX the RASTER layer rewarps ok,
> POLYGON and LINE layers do not.
> Am 17.12.2013 16:11, schrieb Eichner, Andreas - SID-NLKM:
> > Looks like that causes the same effect as setting
> > PROCESSING "LOAD_WHOLE_IMAGE=YES"
> >> Von: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-
> users-
> >> bounces at lists.osgeo.org] Im Auftrag von Heiko Schröter
> >> Gesendet: Dienstag, 17. Dezember 2013 14:09
> >> An: mapserver-users at lists.osgeo.org
> >> Betreff: [mapserver-users] Rewarping/Reprojection with GDAL and -
> wo
> >> To make use of it in mapserver a hint has been given in an old
> >> mailing
> >> thread (sorry, lost the source) to adjust the following code
> snippet
> >> in
> >> resample.c:
> >> Version: mapserver-6.4.0
> >> resample.c
> >> <snip>
> >> /* Project desired extents out by 2 pixels, and then
> strip
> >> to */
> >> /* available
> >> data. */
> >> memcpy( &sOrigSrcExtent, &sSrcExtent, sizeof(sSrcExtent) );
> >> sSrcExtent.minx = floor(sSrcExtent.minx-1.0);
> >> sSrcExtent.maxx = ceil (sSrcExtent.maxx+1.0);
> >> sSrcExtent.miny = floor(sSrcExtent.miny-1.0);
> >> sSrcExtent.maxy = ceil (sSrcExtent.maxy+1.0);
> >> <snap>
> >> Changing the -/+1.0 to -/+1250.0, for example, warps the RASTER
> image
> >> correctly.
> Dipl.-Ing. Heiko Schröter
> Institute of Environmental Physics (IUP) phone: ++49-(0)421-218-
> 62092
> Institute of Remote Sensing (IFE) fax: ++49-(0)421-218-
> 62070
> University of Bremen (FB1)
> P.O. Box 330440 email: schroete at iup.physik.uni-
> bremen.de
> Otto-Hahn-Allee 1
> 28359 Bremen
> Germany
