[mapserver-users] OGR ODBC Layer with Password
Donald Kerr donald.kerr at dkerr.co.uk
Tue Dec 17 12:14:15 PST 2013
Any takers (see email below)? Help appreciated.
Regards,
Donald
-----Original Message-----
From: Donald Kerr [mailto:donald.kerr at dkerr.co.uk]
Sent: 12 December 2013 16:45
To: 'Donald Kerr'
Subject: OGR ODBC Layer with Password
Hi All,
I have a layer that uses OGR to connect to an Microsoft Access database via
ODBC.
CONNECTIONTYPE OGR
CONNECTION "ODBC: MyDNSName,MyTableName" # Requires GEOMETRY_COLUMNS table
(SPATIAL_REF_SYS optional) - Fails if DATA included in this map file
The above works on a database without password protection. When I add a
password to the database, I would expect to be able to connect using the
following line:
CONNECTION "ODBC:Admin/MyPassword at MyDNSName,MyTableName" # Requires
GEOMETRY_COLUMNS table (SPATIAL_REF_SYS optional) - Fails if DATA included
in this map file
But I get the following error in the log file:
[Thu Dec 12 16:22:35 2013].484000 msDrawMap(): WMS/WFS set-up and query,
0.000s [Thu Dec 12 16:22:35 2013].484000
msOGRFileOpen(ODBC:Admin/MyPassword at MyDSNName,MyTableName)...
[Thu Dec 12 16:22:35 2013].484000 OGROPen(ODBC:Admin/MyPassword at MyDSNName)
[Thu Dec 12 16:22:35 2013].515000 msOGRFileOpen(): OGR error. Open failed
for OGR connection in layer `MyLayerName'.
Unable to initialize ODBC connection to DSN for Admin/MyPassword at MyDSNName,
[Microsoft][ODBC Microsoft Access Driver] Not a valid password
The only difference is the username and password being included in the
connection string.
If I run the following at the command line, all works well:
C:\ >ogrinfo ODBC:Admin/MyPassword at MyDSNName,MyTableName
INFO: Open of `ODBC:Admin/MyPassword at MyDSNName,MyTableName'
      using driver `ODBC' successful.
1: MyTableName
It would appear that the Username and Password are being ignored or changed
when used by MapServer since ogrinfo is working correctly and opening the
connection.
Any ideas?
Many thanks.
Regards,
Donald
