[mapserver-users] Admin boundaries styling
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Wed Dec 18 02:22:45 PST 2013
Would it be acceptable to create a new dataset for rendering the borders by converting polygons into linestrings and merging the overlapping segments? With OpenJUMP you cound do it with a single operation Tools - Edit Geometry - Convert - Extract Segments. Select option "Merge resulting segments" and you've done it.
-Jukka Rahkonen-
Frank Broniewski wrote:
> Hi,
> I'm trying to get the styling right for administrative boundaries. The data source
> is a polygon shapefile with administrative boundaries of a certain level. I want to
> have a dashed line style to symbolize the boundary. The layer is used as TYPE
> LINE.
> The style I'm using:
> STYLE
> Color 100 100 100
> Gap 4
> Linecap butt
> Linejoin miter
> Linejoinmaxsize 3
> Pattern 2 6 2 6 2 6 End
> Symbol "circle"
> Width 2
> END
> Problem is that the pattern overlaps where a boundary is drawn more than once
> due to the shared nature of adjacent adminstrative units.
> Since the source is a shapefile there's no topology that would prevent the issue
> and my PostGis DB doesn't support that (yet)*. Here's a screenshot that displays
> the issue:
> http://www.geometrico.lu/devel/mapserver/boundary-styling.png
> As you can see the styling varies greatly. So - does anyone have a clue on how to
> get the styling right? It should look like in the lower right corner of the
> screenshot ...
> Many thanks,
> Frank
> * BTW: can Mapserver handle PostGIS topology geometry types?
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJSsWOfAAoJEHopqW0d1cQVUjcH+wamQP8jJo8BzrX9JYp6mn
> 2h
> rzbk4LYyH6Xf144dnJkfrt7G8eziABT0Zg/RDqE6trqkBGlPxO16wOFbIPunEAZC
> O+veftAYv4pyZbXKvAJF2yXW1L1P/OJNppRO3WnfkZGVDybsWecGkoowl0NdPBg
> L
> Ps4FLcVXhgNxpdOZpwgMMDOHs1VGVuZgRXx02SLm8lmzffnixSCuMUtL45Q9HB
> on
> 62SCRi/nJ1AYAMVC9+2PeRs4Uni+cIAMRS0nXeE988JcXvDmWsazKXZCwG9iuZhz
> WUOuIEpTg2wcH3zEemyHkxJnutW5ryUDCbF/u7cCiCgVHq+NesGEfVS6kWqGW2
> U=
> =Mm2w
> -----END PGP SIGNATURE-----
> mapserver-users at lists.osgeo.org
