[mapserver-users] cannot change coordinate system when using MapCache to serve to ArcGIS clients
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Mon Dec 30 11:26:45 PST 2013
Are you using a recognized EPSG (or other validated) code for defining the County coordinates?  Or maybe a custom EPSG??
Bobb
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Monday, December 30, 2013 1:21 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] cannot change coordinate system when using MapCache to serve to ArcGIS clients
Hello,
For some reason ArcGIS will only consume my MapCache WMS service in GCS_WGS_1984.  This causes the air photos to be reprojected once on the server (County Coordinates-->WGS) and again on the ArcGIS client ( WGS --> County Coordinates).  I would to avoid reprojecting my air photos.  Unfortunately, nothing happens when I open "Change Coordinate System" in ArcMap then select County Coordinates.  Is this an ArcGIS issue, or is there a problem with MapCache?
Thanks
Mark Volz, GISP
GIS Specialist
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
