[mapserver-users] cannot change coordinate system when using MapCache to serve to ArcGIS clients
Mark Volz MarkVolz at co.lyon.mn.us
Mon Dec 30 14:28:00 PST 2013
Brent.
Here is the SRS and Server information.
SRS: 103744, 900913, 103749, 26915, 4326, 3857.   103749 is Lyon county coordinates and it is used by ESRI.
If this is the correct way...  GetCapabilities Document: http://geomoose.lyonco.org/mapcache/cgi-bin/mapserv?map=LyonAirPhotos&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
Server:  http://geomoose.lyonco.org/mapcache?
Mark Volz, GISP
GIS Specialist
Sent: Monday, December 30, 2013 4:10 PM
To: Mark Volz; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] cannot change coordinate system when using MapCache to
So what SRS's are advertised in the MapCache capabilities document?
Is the URL for that publicly available?
From: Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>>
To: "mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>" <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Sent: Tuesday, December 31, 2013 9:14 AM
Subject: [mapserver-users] cannot change coordinate system when using MapCache to
Brent and Bobb.
I am using EPSG 103749, which is ESRI's custom version for our county coordinates.  I added those coordinates into MapServer and MapCache.  MapCache advertises the county coordinates, UTM 15, Google, and apparently GCS_WGS_1984.
-I tried using UTM 15 which is a more common projection.  That did not work.
-I should also mention that I can connect directly from an ArcGIS client to MapServer using county coordinates.  The only coordinate system that MapServer advertises is in our county coordinates.
Thanks
Mark Volz, GISP
GIS Specialist
> Hi Mark,
> Is your WMS service advertising "county coordinates" as a supported CRS?
> If the WMS default CRS is WGS and no other is advertised then (in my limited
> experience) Arc will only request content in an advertised CRS - so your
> default of WGS is the only one it will request.
> Brent Wood
> Hello,
> For some reason ArcGIS will only consume my MapCache WMS service in
> GCS_WGS_1984.? This causes the air photos to be reprojected once on the
> server (County Coordinates-->WGS) and again on the ArcGIS client ( WGS -->
> County Coordinates).? I would to avoid reprojecting my air photos.?
> Unfortunately, nothing happens when I open "Change Coordinate System"
> in ArcMap then select County Coordinates.? Is this an ArcGIS issue, or is
> there a problem with MapCache??
> Thanks
> Mark Volz, GISP
> GIS Specialist
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20131230/0f709bb6/attachment.html>
