[mapserver-users] QGIS vs Mapserver someone use wrong scale ?
Andrea Peri aperi2007 at gmail.com
Mon Feb 11 14:40:49 PST 2013
I set a class rule to show the label in this interval scale:
      LABEL
        COLOR 175 109 134
        OUTLINECOLOR 255 255 255
        OUTLINEWIDTH 1
        MAXSCALEDENOM 300100
        MINSCALEDENOM 1
After I try to test it with QGIS, but I see calling it with qgis the
show of labels in the scale are not so linear as I could guess.
infact
the label ARE NOT SHOWED at 1:299.990
the label ARE NOT SHOWED at 1:300.000
the label are showed at 1:300.001
the label are showed at 1:300.010
the label ARE NOT SHOWED at 1:300.050
the label are showed at 1:300.090
the label ARE NOT SHOWED at 1:300.100
the label ARE NOT SHOWED at 1:300.110
the label ARE NOT SHOWED at 1:300.150
So seem the limit of
1:300.100 I set in the mapfile is not so exactly used.
But I'm not able to understand if is a wrong QGIS calculation of scale
value or is a MapServer trouble.
Any hint is welcome
Andrea Peri
qwerty àèìòù
