[mapserver-users] Installing MapServer 6.2 on IIS7.5
Umberto Nicoletti umberto.nicoletti at gmail.com
Tue Feb 12 00:46:34 PST 2013
Saved you both some time and copied your notes in the wiki:
https://github.com/mapserver/mapserver/wiki/Installing-mapserver-under-IIS
Cheers,
Umberto
On Tue, Feb 12, 2013 at 9:20 AM, Donald Kerr <donald.kerr at dkerr.co.uk>wrote:
> Neil,****
> I have some rough notes for my set up (Classic ASP website wit Openlayers
> – Mapserver WMS/WFS) as follows:****
> **1.      **IIS****
> **a.      **Click Start, Control Panel, Programs, Turn Windows features
> on or off.****
> **b.      **Select Internet Information Services.****
> **c.       **Select Web Management Tools then select IIS Management
> Consule.****
> **d.      **Select World Wide Web Services****
> **e.      **In Application development Features, select ASP, CGI, ISAPI
> Extensions, ISAPI Filters and Server-Side Includes.****
> **f.        **In Common HTTP Features, select Default Document, HTTP
> Errors, HTTP Redirection and Static Content.****
> **g.      **In Health and Diagnostics, select HTTP Logging and Request
> Monitor.****
> **h.      **In Performance Features, select Static Content Compression.***
> **i.        **In Security, select Request Filtering.****
> **j.        **Navigate to http://localhost – An IIS welcome page should
> be shown.****
> **k.       **Run inetmgr.****
> **l.        **Highlight Default Web Site under Sites the right-click,
> Manage Web Site then click Advanced Settings. Change the physical path to
> d:\vmds\web\.****
> **m.    **Double-click ASP in the centre panel of IIS Manager and ensure
> the following are set:****
> **                                                  i.      **Enable
> Parent Paths****
> **n.      **Click on Application Pools in the left hand panel of IIS
> Manager, click DefaultAppPool in the centre panel then click advanced
> settings in the right hand panel. Ensure that Enable 32-Bit Applications is
> set to True.****
> **o.      **Create the following virtual directories in IIS:****
> **                                                  i.      **cgi-bin
>                    d:\mapserver\cgi-bin (Neil, will probably be MS4W
> cgi-bin?)****
> **                                 ii.    **mapserver
> d:\mapserver\wwwroot (Neil, you will probably not require this)****
> **p.    **Mapserver via FastCGI****
> **                                  i.    **Click on Default Web Site
> then double-click Handler Mappings in the centre panel.****
> **                                 ii.    **In the Actions Pane, click
> Add Module Mapping then set the following:****
> **1.     **Request path:         *.exe****
> **2.     **Module:                  FastCgiModule****
> **3.     **Executable:             d:\mapserver\cgi-bin\mapserv.exe****
> **4.     **Name:                     Mapserver via FastCGI****
> **5.     **Click on Request Restrictions and set the following:****
> **a.     **Mapping Tab: Check “Invoke hander … “, then set for “File”.****
> **b.    **Verbs Tab: “One of the following …”, enter “GET,HEAD,POST”.****
> **c.     **Access Tab: Check “Execute”.****
> **                                iii.    **Whilst the “Mapserver via
> FastCGI” handler mapping is highlighted, click on Edit feature permissions
> in the right hand panel then ensure that read, script and execute are
> checked.****
> For 64 bit Mapserver:****
> **2.      **Mapserver x64****
> **a.      **Download x64 version of Mapserver from
> http://www.gisinternals.com/sdk/ ****
> **b.      **Delete all existing files in d:\mapserver\cgi-bin\. These are
> the 32 bit Mapserver files from MS4W.****
> **c.       **From the above download, copy all dlls from /bin/ to
> d:\mapserver\cgi-bin\.****
> **d.      **Copy Mapserv.exe from /bin/ms/apps/ to d:\mapserver\cgi-bin***
> I hope this helps. If you write it up properly (something I should have
> done) then please send me a copy.****
> Regards,****
> Donald****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Neil Crisp
> *Sent:* 12 February 2013 04:39
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Installing MapServer 6.2 on IIS7.5****
> I have successfully installed the latest release of MapServer (6.2beta4)
> on Windows via MS4W using Apache, but I need to get it running under
> IIS7.5.  I haven't been having a good time.****
> The latest documentation (Release 6.3-dev) still has the old IIS 5
> documentation written by Debbie Paqurek back in 2005 and the latest other
> documentation I can find is for IIS 6 and is rather complex.****
> Has anyone successfully installed it on IIS7.5 and if so do you have a
> nice straightforward procedure for it?  Something similar to Debbie's
> instructions, but up to date, would be great.****
> Thanks ****
> Neil Crisp.****
> Thanks ****
> Neil Crisp.****
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130212/579b2fac/attachment-0001.html>
