[mapserver-users] Installing MapServer 6.2 on IIS7.5
Neil Crisp neil_crisp at technologyonecorp.com
Tue Feb 12 20:26:33 PST 2013
Donald, Umberto,
Thanks for your help.  I am still working through the steps with minor
modifications to suit my application and making notes as I go,  I will let
you know how I go.
Cheers,
Neil.
On Tue, Feb 12, 2013 at 7:06 PM, Donald Kerr <donald.kerr at dkerr.co.uk>wrote:
> Thanks, Umberto.****
> As I said to Neil, they’re very rough. Neil can maybe neaten them up a bit
> whilst he’s going through the process of installing on his machine. I’ll do
> the same when I next work on a non- XP machine.****
> Regards,****
> Donald****
> *From:* Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> *Sent:* 12 February 2013 08:47
> *To:* Donald Kerr
> *Cc:* Neil Crisp; mapserver
> *Subject:* Re: [mapserver-users] Installing MapServer 6.2 on IIS7.5****
> Saved you both some time and copied your notes in the wiki:****
> https://github.com/mapserver/mapserver/wiki/Installing-mapserver-under-IIS
> Cheers,****
> Umberto****
> On Tue, Feb 12, 2013 at 9:20 AM, Donald Kerr <donald.kerr at dkerr.co.uk>
> wrote:****
> Neil,****
> I have some rough notes for my set up (Classic ASP website wit Openlayers
> – Mapserver WMS/WFS) as follows:****
> 1.      IIS****
> a.      Click Start, Control Panel, Programs, Turn Windows features on or
> off.****
> b.      Select Internet Information Services.****
> c.       Select Web Management Tools then select IIS Management Consule.**
> d.      Select World Wide Web Services****
> e.      In Application development Features, select ASP, CGI, ISAPI
> Extensions, ISAPI Filters and Server-Side Includes.****
> f.        In Common HTTP Features, select Default Document, HTTP Errors,
> HTTP Redirection and Static Content.****
> g.      In Health and Diagnostics, select HTTP Logging and Request
> Monitor.****
> h.      In Performance Features, select Static Content Compression.****
> i.        In Security, select Request Filtering.****
> j.        Navigate to http://localhost – An IIS welcome page should be
> shown.****
> k.       Run inetmgr.****
> l.        Highlight Default Web Site under Sites the right-click, Manage
> Web Site then click Advanced Settings. Change the physical path to
> d:\vmds\web\.****
> m.    Double-click ASP in the centre panel of IIS Manager and ensure the
> following are set:****
>                                                   i.      Enable Parent
> Paths****
> n.      Click on Application Pools in the left hand panel of IIS Manager,
> click DefaultAppPool in the centre panel then click advanced settings in
> the right hand panel. Ensure that Enable 32-Bit Applications is set to True.
> o.      Create the following virtual directories in IIS:****
>                                                   i.      cgi-bin
>                    d:\mapserver\cgi-bin (Neil, will probably be MS4W
> cgi-bin?)****
>                                  ii.    mapserver
> d:\mapserver\wwwroot (Neil, you will probably not require this)****
> p.    Mapserver via FastCGI****
>                                   i.    Click on Default Web Site then
> double-click Handler Mappings in the centre panel.****
>                                  ii.    In the Actions Pane, click Add
> Module Mapping then set the following:****
> 1.     Request path:         *.exe****
> 2.     Module:                  FastCgiModule****
> 3.     Executable:             d:\mapserver\cgi-bin\mapserv.exe****
> 4.     Name:                     Mapserver via FastCGI****
> 5.     Click on Request Restrictions and set the following:****
> a.     Mapping Tab: Check “Invoke hander … “, then set for “File”.****
> b.    Verbs Tab: “One of the following …”, enter “GET,HEAD,POST”.****
> c.     Access Tab: Check “Execute”.****
>                                 iii.    Whilst the “Mapserver via
> FastCGI” handler mapping is highlighted, click on Edit feature permissions
> in the right hand panel then ensure that read, script and execute are
> checked.****
> For 64 bit Mapserver:****
> 2.      Mapserver x64****
> a.      Download x64 version of Mapserver from
> http://www.gisinternals.com/sdk/ ****
> b.      Delete all existing files in d:\mapserver\cgi-bin\. These are the
> 32 bit Mapserver files from MS4W.****
> c.       From the above download, copy all dlls from /bin/ to
> d:\mapserver\cgi-bin\.****
> d.      Copy Mapserv.exe from /bin/ms/apps/ to d:\mapserver\cgi-bin****
> I hope this helps. If you write it up properly (something I should have
> done) then please send me a copy.****
> Regards,****
> Donald****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Neil Crisp
> *Sent:* 12 February 2013 04:39
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Installing MapServer 6.2 on IIS7.5****
> I have successfully installed the latest release of MapServer (6.2beta4)
> on Windows via MS4W using Apache, but I need to get it running under
> IIS7.5.  I haven't been having a good time.****
> The latest documentation (Release 6.3-dev) still has the old IIS 5
> documentation written by Debbie Paqurek back in 2005 and the latest other
> documentation I can find is for IIS 6 and is rather complex.****
> Has anyone successfully installed it on IIS7.5 and if so do you have a
> nice straightforward procedure for it?  Something similar to Debbie's
> instructions, but up to date, would be great.****
> Thanks ****
> Neil Crisp.****
> Thanks ****
> Neil Crisp.****
> http://lists.osgeo.org/mailman/listinfo/mapserver-users****
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2013.0.2897 / Virus Database: 2639/6097 - Release Date: 02/11/13*
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130213/d49aed11/attachment-0001.html>
