[mapserver-users] mapserver 6.2.0 perl mapscript
Andy Colson
andy at squeakycode.net
Wed Feb 13 12:30:08 PST 2013
Yep, exactly what I hit.
And if there is a patch for it, I'll just wait on my packaging. Awesome!
Thanks
-Andy
On 2/13/2013 2:25 PM, Umberto Nicoletti wrote:
> Perhaps then you've hit this issue:
> https://github.com/mapserver/mapserver/issues/4528
> Let me know and I'll make sure to push it forward asap.
> br,
> Umberto
> On Wed, Feb 13, 2013 at 9:03 PM, Andy Colson <andy at squeakycode.net
> <mailto:andy at squeakycode.net>> wrote:
> I was not doing a toplevel make install, so it didnt copy
> libmapserver-6.2.0.so <http://libmapserver-6.2.0.so>.
> But, even after fixing my script, and installing:
> usr/local/lib64/perl5/auto/__mapscript/mapscript.so
> usr/lib/libmapserver.la <http://libmapserver.la>
> usr/lib/libmapserver-6.2.0.so <http://libmapserver-6.2.0.so>
> I get the same error. Also:
> ldd /usr/local/lib64/perl5/auto/__mapscript/mapscript.so
> doesn't show it using libmapserver.
> -Andy
> On 2/13/2013 1:30 PM, Umberto Nicoletti wrote:
> As of 6.2 mapscript is built as a shared lib and depends on
> mapserver
> which therefore must have been installed before.
> Umberto
> On Feb 13, 2013 8:27 PM, "Andy Colson" <andy at squeakycode.net
> <mailto:andy at squeakycode.net <mailto:andy at squeakycode.net>>> wrote:
> On 2/13/2013 1:19 PM, Umberto Nicoletti wrote:
> Did you run make install in the MapServer top level
> directory?
> Umberto
> On Feb 13, 2013 7:52 PM, "Andy Colson"
> <andy at squeakycode.net <mailto:andy at squeakycode.net>
> <mailto:andy at squeakycode.net> <mailto:andy at squeakycode.net
> <mailto:andy at squeakycode.net>>>__> wrote:
> Hi all,
> I'm having problems updating to 6.2.0. I can get perl
> mapscript to
> compile and install ok, but when I try to run
> anything:
> # perl dump.pl <http://dump.pl> <http://dump.pl>
> <http://dump.pl>
> perl: symbol lookup error:
> /usr/local/lib64/perl5/auto/______mapscript/mapscript.so:
> undefined
> symbol: msSetup
> Any hints what might be wrong?
> Thanks for your time,
> -Andy
> I believe so. I'm actually making a slackware package
> (which I've
> done for 6.0.3 as well), and then I install the package.
> ls -l /usr/local/lib64/perl5/auto/____mapscript/mapscript.so
> does show it as todays date, so I'm pretty sure its new.
> I will go try to build it by hand and verify its not the
> packaging
> script that's a problem.
> -Andy
