[mapserver-users] posting variable to map file from html page
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 14 07:49:42 PST 2013
On 2/14/2013 10:11 AM, Murat Beyhan wrote:
> Dear Friend
> After installing mapserver 6.0.1 I have faced a problem that
> I could not post string variable into the map file.
> It was working well for mapserver 5.4.2 but it doesn't work for new version
> from html file I have sending eq_id to the map file
> and in layer I use the following
> <SrcSQL>SELECT sta_id,latitude,longitude from pgav where eq_id like
> "%eq_id%" </SrcSQL>
> it was worked for mapserver 5.4.2 but I could not sent when I installed
> new version of map file.
> May be it caused by new apache2 server. But in case please help me.
> Regards...
> Murat
In the newer version of mapserver you have to add validation regexs to
all variables. This is a security update.
read: http://mapserver.org/cgi/runsub.html
-Steve W
