[mapserver-users] Photo Viewer
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Thu Feb 14 08:53:49 PST 2013
I would think it could be done, your extent would be given in pixels. Full extent is given as 0 0 width-1 height-1. Depends if the raster code respects the layer TRANSFORM parameter.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Thursday, February 14, 2013 10:34 AM
To: Weisbender, Eric; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Photo Viewer
Eric,
Interesting idea.  I remember a thread a few years back about something similar being asked.
As far as the geo-referencing part, you can simply use the size of the image as your reference coordinate system for each image.  Mapserver is more generally suit towards combining different data into a single output, thus the need for a coordinate system to reference more than one layer.
So, the real question boils down to a technique for fooling MapServer into some sort of projection some how for each image.   Let me think on this a bit.  I wonder though about setting up something to register images to a location via a loading form which grabs the image size, etc.  Then they are put away with the sudo projection assigned to each image at the uploading point.
Bobb
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Weisbender, Eric
Sent: Thursday, February 14, 2013 10:03 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Photo Viewer
I would like to use MapServer as just an unreferenced image viewer for jpgs so I can zoom in and out on the image.  Everything I read says that images have to be georeferenced.  Any idea or even examples would be greatly appreciated.
Thanks,
Eric Weisbender
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130214/1f9c8288/attachment-0001.html>
