[mapserver-users] php-mapscript not working
Daniel Morissette dmorissette at mapgears.com
Wed Feb 20 19:39:48 PST 2013
I may be wrong, but I don't think the following line in your mapfile
will do anything:
     CONFIG "MS_DEBUGLEVEL" "4"
Instead, inside a mapfile I'd suggest using:
     DEBUG 4
and then see if you get some log output...
Daniel
On 13-02-18 3:34 PM, Vince Miller wrote:
> I recently upgraded my development server and updated all the relevant software. The only thing that doesn't work is mapserver/php-mapscript.
> Here's the particulars:
> After Ubuntu server 12.04, postgres 9.1, apache2, and php5 seemingly (since they work) installed fine, the installation commands were :
> sudo apt-add-repository ppa:ubuntugis/ppa
> sudo apt-get update
> sudo apt-cache search postgis
> sudo apt-get install postgis postgresql-9.1-postgis mapserver-bin php5-mapscript cgi-mapserver
> ./mapserv -v # result:
>     MapServer version 6.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG sUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> The file php_mapscript.so is in /usr/lib/php5/20090626 and phpinfo() suggests that everything is fine, but my PHP script script dies on this line:
> <?php
> $map = ms_newMapObj(__MAPS_PATH__ . 'eunomi0.map');
> The mapfile eunomi0.map is:
> MAP
>    CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
>    OUTPUTFORMAT
>      NAME 'AGG_Q'
>      DRIVER AGG/PNG
>      IMAGEMODE RGB
>      FORMATOPTION "QUANTIZE_FORCE=ON"
>      FORMATOPTION "QUANTIZE_DITHER=OFF"
>    END
>    FONTSET "font.list"
>    SYMBOLSET "symbols.sym"
>    EXTENT         -180 -90 180 90
>    SIZE           1190 595
>    MAXSIZE        2048
>    IMAGECOLOR     173 178 161
>    STATUS         OFF
> ... 20 or so LAYER objects, raster pngs and posgis vectors
> The mapserver.log file is empty. Any clues?
> This worked fine on my old server.
> Thanks a bunch,
> Vince
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
