[mapserver-users] problem with TRUETYPE and GEOMTRANSFORM 'labelpoly': wrong calculation by mapserver ?
Oliver Christen
oliver.christen at camptocamp.com
Fri Feb 22 01:23:51 PST 2013
Hello Steve
I have created a test case and opened a issue:
https://github.com/mapserver/mapserver/issues/4595
as stated in the issue, it is possible the problem is caused by the
TRUETYPE font itself, but I dont have the knowledge to debug the
processing inside mapserver to find out.
best regards
Oliver
> Oliver: Any chance you can create a test case and a ticket?
> Steve
> _______________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Oliver Christen [oliver.christen at camptocamp.com]
> Sent: Thursday, February 21, 2013 8:40 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] problem with TRUETYPE and GEOMTRANSFORM 'labelpoly': wrong calculation by mapserver ?
> hello dear mailinglist
> Im having a strange result when using a TRUETYPE symbol used as LABEL,
> with a GEOMTRANSFORM 'labelpoly' to give some background color of my symbol,
> the background polygon created by the GEOMTRANSFORM 'labelpoly' is
> smaller than my symbol, ending in a not so great result, as seen on this
> example:
> http://dev.camptocamp.com/files/mapserver/test_train_symbol.png
> also, the OUTLINECOLOR show some color inside the symbol, something I
> dont understand at all.
> if someone could possibly tell me how to adjust the labelpoly size and
> explain me the OUTLINECOLOR behavior in this case, I would be very grateful.
> here is the CLASS used to render that layer:
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT HPMDRG
> SIZE 20
> ANTIALIAS TRUE
> COLOR 0 51 153 # dark blue
> OUTLINECOLOR 255 0 0 # red, just for testing, I dont understand
> why there is an outline inside the symbol
> STYLE
> COLOR 0 255 255 # background cyan rectangle, not the correct size
> END
> POSITION cc
> END
> TEXT "1"
> END
> Im using mapserver 6.3.0 on debian
> thank you for reading this,
> best regards
> Oliver
> Camptocamp SA
> Oliver Christen
> PSE A
> CH-1015 Lausanne
> www.camptocamp.com
Camptocamp SA
Oliver Christen
PSE A
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
