[mapserver-users] How Filter items only if provided parameter
Andrea Peri aperi2007 at gmail.com
Sat Feb 23 04:15:12 PST 2013
I need to set a layer to allow to retrieve in the response all the
elements available in the layer, and when the request has a specific
parameter it should apply a filter to limit the show to only the
filtered geometries.
To do this until now I have set this configuration:
LAYER
    DATA "geometry from table using unique gid srid=25832"
    FILTER "PK_FIELD like '%idvalue%' "
    VALIDATION
      'idvalue' '^[a-zA-Z0-9\-_]+$'
    END
   METADATA
      'default_idvalue' '%'
This configuration work pretty well when the PK is a string field.
Infact is the request has no the idvalue parameter it show all the
records , thx to the "default_idvalue  %" definitioni,
instead if the request has a parameter as example
..&idvalue=xxx1
It show only the specific item having PK_FIELD=xxx1
Now I have the same need for a layer where the PK is numeric.
With this layer the solution described seem don't work, infact the
is not working with a numeric field.
There same other solution to have the same result?
I need to show all the records and apply the filter only when there is
a specific parameter in the request.
Thx,
Andrea Peri
qwerty àèìòù
