[mapserver-users] First attempt on Maserver
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 28 12:06:25 PST 2013
On 2/28/2013 2:14 PM, Stefanos Anastasiou wrote:
> Hello everyone!
> I'm quite new to mapserver and I'm experimenting with the 2 first
> examples of Kropla's book... the first one, that is supposed to produce
> just an image... I click on "Click me" button and the message I get is:
> Not Found
> The requested URL /cgi-bin/mapserv was not found on this server
> I don't get it.. according to the instructions cp mapserv /var/www/cgi-bin
> Why isn't it working?
OK, there are a bunch of assumptions in the above:
assumes the apache or your webserver is configured to look for cgi-bin
files in this directory
assumes that the directory already exists. what does these report:
file /var/www/cgi-bin
ls -l /var/www/cgi-bin/mapserv
/var/www/cgi-bin/mapserv -v
If the above looks ok, then you probably need to look at the apache
config. If you changed the apache config as part of your install, have
you restarted apache:
sudo /etc/init.d/apache2 restart
or
sudo /etc/init.d/apache restart
-Steve W
