[mapserver-users] GetLegendGraphics don't return correctly the point symbol
Andrea Peri
aperi2007 at gmail.com
Tue Jan 8 04:33:20 PST 2013
Actually it is returning something like this:
OOOOOOO
OOOOOOO
OOOOOOO
OOOOOOO
These seem a polygon filled with many circles internally
Instead I would like to obtain something like this:
O
2013/1/8 thomas bonfort <thomas.bonfort at gmail.com>:
> what are you trying to obtain ?
> On 8 January 2013 13:16, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> many thx for response.
>>> Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
>> No.
>>> Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
>> I try to removing the geomtransform, but it do disappeared all symbol
>> (ie polygons lesser then defined area).
>> But I see something of good try-ing to increase the size and also
>> adding a lesser than default outline.
>> ie:
>> size 6
>> with 0.1
>> and leaving the GeomTransform 'start'
>> It is surely better, but still it seem a polygon filled with many circles.
>> Instead my rendering is 1 only point for an entire polygon.
>> This seem not clearly understandable from the returned legend.
>> This is the result:
>> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
>> Many thx for hints,
>> Andrea.
>>> thomas
>>> On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>> Hi,
>>>> I have a polygon layer that at some scales try to render with a symbol.
>>>> To do this I define a specific symbol style:
>>>> SYMBOL
>>>> NAME "circlefill"
>>>> TYPE ellipse
>>>> POINTS
>>>> 1 1
>>>> END
>>>> FILLED true
>>>> ANCHORPOINT 0.5 0.5
>>>> END
>>>> And use this in the class definition as here where I put two class one
>>>> with a polygon rendering (when area bigger) and a second class with
>>>> point rendering when area is lower:
>>>> CLASS
>>>> NAME 'area superiore a 1ha'
>>>> EXPRESSION ( ([AREA] >= 1000000) )
>>>> GROUP 'delimitazione zona di vincolo'
>>>> MAXSCALEDENOM 4000100
>>>> MINSCALEDENOM 50100
>>>> STYLE
>>>> COLOR "#F2BAFE80"
>>>> OUTLINECOLOR "#F2BAFE"
>>>> ANTIALIAS false
>>>> END
>>>> END
>>>> CLASS
>>>> NAME 'area inferiore a 1ha'
>>>> EXPRESSION ( ([AREA] < 1000000) )
>>>> MINSCALEDENOM 50100
>>>> STYLE
>>>> GEOMTRANSFORM 'start'
>>>> SYMBOL 'circlefill'
>>>> SIZE 4
>>>> COLOR "#F2BAFEFF"
>>>> ANTIALIAS false
>>>> END
>>>> END
>>>> Unfortunately the getlegendgraphis don't recognize this symbol
>>>> definition and seem to render always using a polygon style (because
>>>> the layer is originally a polygon).
>>>> This is what return the GetLegendGraphics.
>>>> Am I wrong something in the class definitions ?
>>>> Many thx,
>>>> Andrea Peri
>>>> qwerty àèìòù
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
