[mapserver-users] GetLegendGraphics don't return correctly the point symbol
Andrea Peri
aperi2007 at gmail.com
Tue Jan 8 06:48:20 PST 2013
ok,
thx for help.
It don't seem to be a bug, but, instead an enhancement.
2013/1/8 thomas bonfort <thomas.bonfort at gmail.com>:
> correct, I've just checked and geomtransform handling isn't supported
> for legend rendering.
> thomas
> On 8 January 2013 13:51, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi,
>> I try the
>> geomtransform centroid
>> Unfortunately still the GetLegendGraphics return the
>> OOOO
>> OOOO
>> OOOO
>> This is the call sample:
>> http://web.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wmstematici&service=wms&request=GetLegendGraphic&version=1.3.0&format=image/png&SLD_VERSION=1.1.0&layer=rt_tematici.idarch_a_1.rt&scale=60000
>> 2013/1/8 Andrea Peri <aperi2007 at gmail.com>:
>>> oh oh. :)
>>> I don't know it was existant. It is not in the documentation. :)
>>> I try it instantly.
>>>> then you need geomtransform centroid, no?
>>>> On 8 January 2013 13:33, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>> Actually it is returning something like this:
>>>>> OOOOOOO
>>>>> OOOOOOO
>>>>> OOOOOOO
>>>>> OOOOOOO
>>>>> These seem a polygon filled with many circles internally
>>>>> Instead I would like to obtain something like this:
>>>>> O
>>>>>> what are you trying to obtain ?
>>>>>> On 8 January 2013 13:16, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>>> Hi,
>>>>>>> many thx for response.
>>>>>>>> Do you have a SIZEUNIT or SYMBOLSCALEDENOM set on your layer ?
>>>>>>> No.
>>>>>>>> Try increasing/setting your CLASS->STYLE->SIZEs, and remove the GEOMTRANSFORM
>>>>>>> I try to removing the geomtransform, but it do disappeared all symbol
>>>>>>> (ie polygons lesser then defined area).
>>>>>>> But I see something of good try-ing to increase the size and also
>>>>>>> adding a lesser than default outline.
>>>>>>> ie:
>>>>>>> size 6
>>>>>>> with 0.1
>>>>>>> and leaving the GeomTransform 'start'
>>>>>>> It is surely better, but still it seem a polygon filled with many circles.
>>>>>>> Instead my rendering is 1 only point for an entire polygon.
>>>>>>> This seem not clearly understandable from the returned legend.
>>>>>>> This is the result:
>>>>>>> Many thx for hints,
>>>>>>> Andrea.
>>>>>>>> thomas
>>>>>>>> On 8 January 2013 12:18, Andrea Peri <aperi2007 at gmail.com> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I have a polygon layer that at some scales try to render with a symbol.
>>>>>>>>> To do this I define a specific symbol style:
>>>>>>>>> SYMBOL
>>>>>>>>> NAME "circlefill"
>>>>>>>>> TYPE ellipse
>>>>>>>>> POINTS
>>>>>>>>> 1 1
>>>>>>>>> END
>>>>>>>>> FILLED true
>>>>>>>>> ANCHORPOINT 0.5 0.5
>>>>>>>>> END
>>>>>>>>> And use this in the class definition as here where I put two class one
>>>>>>>>> with a polygon rendering (when area bigger) and a second class with
>>>>>>>>> point rendering when area is lower:
>>>>>>>>> CLASS
>>>>>>>>> NAME 'area superiore a 1ha'
>>>>>>>>> EXPRESSION ( ([AREA] >= 1000000) )
>>>>>>>>> GROUP 'delimitazione zona di vincolo'
>>>>>>>>> MAXSCALEDENOM 4000100
>>>>>>>>> MINSCALEDENOM 50100
>>>>>>>>> STYLE
>>>>>>>>> COLOR "#F2BAFE80"
>>>>>>>>> OUTLINECOLOR "#F2BAFE"
>>>>>>>>> ANTIALIAS false
>>>>>>>>> END
>>>>>>>>> END
>>>>>>>>> CLASS
>>>>>>>>> NAME 'area inferiore a 1ha'
>>>>>>>>> EXPRESSION ( ([AREA] < 1000000) )
>>>>>>>>> MINSCALEDENOM 50100
>>>>>>>>> STYLE
>>>>>>>>> GEOMTRANSFORM 'start'
>>>>>>>>> SYMBOL 'circlefill'
>>>>>>>>> SIZE 4
>>>>>>>>> COLOR "#F2BAFEFF"
>>>>>>>>> ANTIALIAS false
>>>>>>>>> END
>>>>>>>>> END
>>>>>>>>> Unfortunately the getlegendgraphis don't recognize this symbol
>>>>>>>>> definition and seem to render always using a polygon style (because
>>>>>>>>> the layer is originally a polygon).
>>>>>>>>> This is what return the GetLegendGraphics.
>>>>>>>>> Am I wrong something in the class definitions ?
>>>>>>>>> Many thx,
>>>>>>>>> Andrea Peri
>>>>>>>>> qwerty àèìòù
>>>>>>>>> _______________________________________________
>>>>>>>>> mapserver-users mailing list
>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>>> Andrea Peri
>>>>>>> qwerty àèìòù
>>>>> Andrea Peri
>>>>> qwerty àèìòù
>>> Andrea Peri
>>> qwerty àèìòù
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
