[mapserver-users] Variables not processed in 6.0.2
Hans
hans at gso.nl
Sun Jan 13 02:08:21 PST 2013
hi
I am new in mapserver and testing with versions 5.2.2 and 6.2.0.
I found out that filtering in a layer with a url option does work in 5.2.2
but not in 6.2.0.
I have this layer :
NAME demo
STATUS ON
TYPE POLYGON
METADATA
'default_percsize' '1'
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=192.168.3.8 dbname=postgis20 user=postgres
password=*** port=5432"
DATA "geometry from map_05 using unique geb_id using srid=28992"
FILTER "perc_10 in ( %percsize% )"
and there is "&percsize=10" in the url.
When using MapServ.exe 5.2.2. this works fine, but when using 6.2.0 it does
not process the percsize parameter from the URL when I see the error
message.
Failed to draw layer named 'demo'. msPostGISLayerWhichShapes(): Query error.
Error executing query: ERROR: syntax error at or near "%" LINE 1:
....8,-10179.25 306866.8))',28992) and (perc_10 in ( %percsize%... ^
msValidateParameter(): Regular expression error. Parameter pattern
validation failed.
I see %percsize% is still in the SQL, so it was not replaced???
How can I fix this?
Hans
View this message in context: http://osgeo-org.1560.n6.nabble.com/Variables-not-processed-in-6-0-2-tp5027141.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
