[mapserver-users] Variables not processed in 6.0.2 CRM:0001794
Hans
hans at gso.nl
Sun Jan 13 22:57:29 PST 2013
Thank you for you're help.
You are right.
Adding a validation did work.
Kind regards
Hans
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: zondag 13 januari 2013 11:18
To: Hans; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Variables not processed in 6.0.2
Validation became compulsory in version 6.0. Read
http://mapserver.org/cgi/runsub.html#validation and add validation block for
percsize.
-Jukka Rahkonen-
________________________________________
Hans wrote:
> hi
> I am new in mapserver and testing with versions 5.2.2 and 6.2.0.
> I found out that filtering in a layer with a url option does work in
> 5.2.2 but not in 6.2.0.
> I have this layer :
NAME demo
STATUS ON
TYPE POLYGON
METADATA
'default_percsize' '1'
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=192.168.3.8 dbname=postgis20 user=postgres
password=*** port=5432"
DATA "geometry from map_05 using unique geb_id using srid=28992"
FILTER "perc_10 in ( %percsize% )"
and there is "&percsize=10" in the url.
When using MapServ.exe 5.2.2. this works fine, but when using 6.2.0 it does
not process the percsize parameter from the URL when I see the error
message.
Failed to draw layer named 'demo'. msPostGISLayerWhichShapes(): Query error.
Error executing query: ERROR: syntax error at or near "%" LINE 1:
....8,-10179.25 306866.8))',28992) and (perc_10 in ( %percsize%... ^
msValidateParameter(): Regular expression error. Parameter pattern
validation failed.
I see %percsize% is still in the SQL, so it was not replaced???
How can I fix this?
Hans
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Variables-not-processed-in-6-0-2-tp50271
41.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130114/d8ae22d9/attachment.bin>
