[mapserver-users] How retrieve the maxsize information with anhttprequest
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jan 30 02:18:12 PST 2013
I am a WMS server admin myself and I would not be worried about such use. They are just GetMaps and 20 or 100 GetMaps more in not an attack for my mind. Think about any OpenLayers application sending tiled GetMaps for a WMS server. They typically send more than 50 requests per every pan or zoom. Naturally when searching for the maximum image size there would be a few rather big WIDTHs and HEIGTHs but it would be enough to do the scanning once per session or even better, save the values on your computer for future needs. If the result is that WMS client caches some data it would mean less new GetMaps for our server later and that would be fine.
-Jukka Rahkonen-
Eichner, Andreas wrote:
> Although this would work you definitely will loose some friends out there if
> you go and set there server under attack :( Lets say you start with 400px and
> the server sets a limit of 4096px then you will request 400px, 800px, 1600px,
> 3200px 6400px, 4800px, 4000px, 4400px, 4200px, 4100px, 4050px, 4075px... to
> get an accuracy of <32px. And in general limits on width and height are
> indepenent of each other and should be discovered separatly. Now consider
> that on a server that's already under load. You can go with it but you won't be
> a nice guy anymore...
> > How about making an utility that captures the layer bounds from
> > GetCapabilities, takes the centre point of the bounds, checks the
> > min/max scale limits from the GetCapabilities and then calculates a
> > reasonable BBOX and makes a GetMap query with WIDTH=400 and
> > HEIGTH=400. By increasing the outputsize incrementally the server
> > sooner or later sends back something else than a valid image and that
> > was it.
> > -Jukka Rahkonen-
