[mapserver-users] csv join in mapscript/OGR
Even Rouault
even.rouault at mines-paris.org
Mon Jul 1 13:25:53 PDT 2013
Le lundi 01 juillet 2013 14:17:17, Minka Stoyanova a écrit :
> Hello,
> I have a point shape layer and I would like to color each point according
> to a number in a csv file= The csv file is:
> id,color
> 1080,2
> 1090,4
> 11,2
> 12,5
> The ID column is the same as the NUMBER column in the shape file.
> This is my layer:
> LAYER # Stations point layer 1 begins here
> NAME "meteo_oper"
> CONNECTIONTYPE ogr
> CONNECTION "../data/ESRI/meteo_oper.shp"
> DATA "SELECT * FROM meteo_oper LEFT JOIN 'CSV:SPI201301.csv' ON
> meteo_oper.NUMBER=SPI201301.id"
> STATUS ON
> TYPE point
> CLASS
> SYMBOL 'circle'
> SIZE 8
> COLOR 0 255 0
> OUTLINECOLOR 0 0 0
> END
> DEBUG ON
> END # Stations point layer 1 ends here
> And when I use OGR from command line to test my map-file:
> I receive:
> msDrawMap(): Image handling error. Failed to draw layer named 'meteo_oper'.
> <br>
> msOGRFileOpen(): OGR error. ExecuteSQL(SELECT * FROM meteo_oper LEFT JOIN
> 'CSV:SPI201301.csv' ON meteo_oper.NUMBER=SPI201301.id) failed.
> SELECT from table CSV:SPI201301.csv failed, no such table/featureclass.
> <br> Segmentation fault
I don't reproduce the segmentation fault with mapserver latest dev version. I
only get the error.
Anyway the solution is to fix your SQL request.
It should be "SELECT * FROM meteo_oper LEFT JOIN 'CSV:SPI201301.csv'.SPI201301
ON meteo_oper.NUMBER=SPI201301.id"
Note the syntax for the table in the LEFT JOIN : 'datasource'.layer_name
More generally, I'd encourage you debugging your SQL requests with ogrinfo
first.
e.g :
ogrinfo meteo_oper.shp -sql "SELECT * FROM meteo_oper LEFT JOIN
'CSV:SPI201301.csv'.SPI201301 ON meteo_oper.NUMBER=SPI201301.id"
> Any idea?
> Minka
Geospatial professional services
http://even.rouault.free.fr/services.html
