[mapserver-users] A problem about setting transparent raster layer.
thomas bonfort
thomas.bonfort at gmail.com
Thu Jul 18 02:54:02 PDT 2013
(please keep your messages on the list)
change pc256 to rgba in your mapfile.
add format:"image/png" to your openlayers options (same level as
alpha:true, which is not needed).
That said, there still very well could be a bug in the raster
classification code as opacity wasn't a first class citizen back in
the GD days....
as for client side opacity: add opacity:0.5 to your javascript (same
level as isBaseLayer)
thomas
On 18 July 2013 11:46, Guo YU <yuguo365 at gmail.com> wrote:
> Dear Thomas,
> Thanks for your reply.
> The mapserver I am using is from MS4W, so it is MS4W Setup Installer
> v3.0.6 (May 26, 2012).
> What Do you mean by use opacity at the client level? Where should I
> set it?
> I changed the driver from GD to AGG, but nothing changed.
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "AGG/PNG"
> EXTENSION "png"
> IMAGEMODE "PC256"
> TRANSPARENT on
> END
> On Thu, Jul 18, 2013 at 10:38 AM, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:
>> Guo,
>> Why not use opacity at the client level only ?
>> That said, this does seem like a bug. Can you specify which mapserver
>> version you are using, and which outputformat your are using (and if
>> you are using a GD one, try switching to AGG).
>> thomas
>> On 18 July 2013 11:28, Guo YU <yuguo365 at gmail.com> wrote:
>> > Dear All,
>> > Since I need to show the code and figures about my problem, I post
>> > it
>> > on the Stack Exchange.
>> > I got problem with Setting a Transparent Raster Layer and then show this
>> > layer though OpenLayer.
>> > Here is the link :
>> > http://gis.stackexchange.com/questions/66388/how-to-make-a-raster-layer-transparent-via-mapserver
>> > Thanks for your time.
>> > YU Guo
>> > MSc. Hydroinformatics and Water Management
>> > Email: yuguo365 at gmail.com
>> > Phone: +33 668 195803
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> YU Guo
