[mapserver-users] Using SIZEUNITS in MapFile with OpenLayers: works being served as WMS Layer, but not OpenLayers.Layer.MapServer
thomas bonfort
thomas.bonfort at gmail.com
Tue Jul 23 10:32:24 PDT 2013
David,
You are probably missing a "UNITS dd" at the map level. It works with
WMS because the SRS included in the WMS call will set the map.units to
dd automatically.
thomas
On 23 July 2013 19:23, David Pardy <dpardy87 at gmail.com> wrote:
> Hello, I've been struggling on this issue and it seems SIZEUNITS is not
> being recognized correctly without using WMS (which, really should not be a
> factor. It should be simpler not using WMS).
> SIZEUNITS units default is pixels. I am trying to use miles. In my html file
> I have
> var cust = new OpenLayers.Layer.MapServer("POIs",
> "http://192.168.2.164/cgi-bin/mapserv.exe", {map:
> "/data2/html/html2/david_POIs4.map", layers: ['POIs']}, {singleTile: true}
> My Mapfile layer (POIs) consists of this:
> LAYER
> NAME POIs
> DEBUG 5
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION 'PointsOfInterest_Latest.db'
> DATA 'POIs'
> STATUS ON
> SIZEUNITS miles
> LABELITEM "name"
> CLASS
> STYLE
> SYMBOL 'Airport'
> COLOR 8 29 118
> WIDTH 2
> SIZE 200
> END
> #STYLE
> # SYMBOL 'City'
> # COLOR 8 29 118
> # SIZE 6
> #END
> LABEL
> FONT "andalewt"
> TYPE truetype
> ENCODING "UTF-8"
> MINSIZE 9
> MAXSIZE 9
> POSITION AUTO
> PARTIALS FALSE
> COLOR 8 29 118
> OFFSET 1 1
> PRIORITY 10
> BUFFER 0
> END # LABEL
> END
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> END
> I have the SIZE set to 200 so the radius will be 100 miles. As you can see I
> commented out the second symbol commented out for now: just trying to get
> something working.
> It also seems that whether the SIZE value is 200 or 10 (any number, really),
> the circles are still huge: more or less taking up the whole map. Whether
> the value is 200 or 10 miles (and working correctly), these circles should
> not be very big on the farthest zoom level out in a standard OpenLayers map.
> I posted two pictures here to give you an idea of what I'm talking about:
> http://imgur.com/a/DhK3Y
> The first picture is correct: the data is being served as a WMS layer.
> The second picture is incorrect: the data is being served as a MapServer
> layer.
> I do not understand how removing WMS and instead using a MapServer layer for
> OL is generating behavior such as this.
> Any input on this issue is appreciated.
> mapserver-users at lists.osgeo.org
