[mapserver-users] No Postgresql mapserver images
Thomas Gratier
osgeo.mailinglist at gmail.com
Sat Jul 27 14:01:15 PDT 2013
Hello,
It seems to be more PostGIS related. Run the legacy.sql or
legacy_minimal.sql
See http://postgis.net/docs/postgis_installation.html for more details
But maybe, I'm wrong...
Regards
Thomas Gratier
2013/7/27 Michael McInnis <mmcinnis59 at msn.com>
> Problem: Although I can use my mapserver install to draw shapefile maps
> I can’t draw maps from my postgres source. I can also display the postgres
> points in QGIS so I’m not sure what the problem is in mapserver.
> Ideas? Thanks in Advance !
> http://mapserver0/cgi-bin/mapserv?map=/media/D_Drive/www/gis/postgresMap.map&layer=airports&mode=map
> msDrawMap(): Image handling error. Failed to draw layer named 'airports'.
> msPostGISLayerWhichShapes(): Query error. Error (ERROR: function
> geomfromtext(unknown, integer) does not exist LINE 1: ...,'hex') as
> geom,"oid" from airports where geom && GeomFromTe... ^ HINT: No function
> matches the given name and argument types. You might need to add explicit
> type casts. ) executing query: select
> encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex') as geom,"oid" from
> airports where geom && GeomFromText('POLYGON((-180.180360721443
> -90,-180.180360721443 90,180.180360721443 90,180.180360721443
> -90,-180.180360721443 -90))',find_srid('','airports','geom'))
> postgresMap.map file:
> MAP NAME airports EXTENT -180 -90 180 90
> SIZE 1000 500
> #SHAPEPATH "./data"
> SYMBOL
> NAME "circle-filled"
> TYPE ELLIPSE
> FILLED TRUE
> POINTS 1 1 END
> END
> LAYER
> CONNECTIONTYPE POSTGIS
> NAME airports
> CONNECTION "host=localhost dbname=Airports user=xxxx
> password=xxxx port=5432"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "geom From airports"
> #DATA "geom From (select icao, geom From airports) as subquery
> using unique icao using srid=4326"
> STATUS ON
> TYPE POINT
> CLASS
> NAME "airportsClass"
> SYMBOL 'circle-filled'
> SIZE 2
> COLOR 255 22 22
> END
> END # Class
> END # Layer
> END # Map File
> Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130727/6a311567/attachment.html>
