[mapserver-users] Mapcache and partial reseeding
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Fri Jun 7 11:16:31 PDT 2013
Thanks, sounds great. I wonder where all this is documented? I have been reading this page which does not mention "mode=delete" or "force" http://www.mapserver.org/trunk/mapcache/seed.html. Doy you know of any other valuable but hidden features?
-Jukka-
thomas bonfort wrote:
On 7 June 2013 17:48, Rahkonen Jukka <jukka.rahkonen at mmmtike.fi<mailto:jukka.rahkonen at mmmtike.fi>> wrote:
How well does Mapcache seeder tool handle the case when the original big aerial image coverage is updated little by little so that the hole cycle takes 3 to 6 years? Reseeding the whole cache every time when a batch of new images is received does not feel like a reasonable solution.
you can look into the ogr support in the seeder, by giving a wkt/shapefile/whatever of the area you want to reseed.
A) Can the seeder tool ake a fast delete for all tiles which intersect the update area geometry so that it is guaranteed that outdated tiles are not delivered. Only high zoom levels (Z greater than X) should be purged. Low zoom levels may stay as they are because they are not used for interpretation.
depends on what you call fast... the tiles intersecting the area of interest need to be iterated and deleted, depending on the area and zoom levels that can take some time.
mode=delete
ogr source => where you want to delete tiles
zoom=X,21
B) Can the seeding tool reseed those areas?
force
ogr source
zoom=X,21
C) Is the behaviour similar for disk cache and Berkeley DB cache?
the behavior is identical. the performance is up to you to measure (I have no metrics to give you).
regards,
thomas
-Jukka Rahkonen-
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
