[mapserver-users] Select the dataset at runtime
Andrea Peri
aperi2007 at gmail.com
Tue Jun 18 15:31:16 PDT 2013
thx for response.
I see the example. Its pretty interesting.
Also another option I found in the documentation:
http://mapserver.org/cgi/runsub.html
I see in the MS6.2 should be possible to act on
DATA and DATAPATTERN.
I guess this could be a good choice, but no other information on this and
how to use.
Is this runtime substitution for DATA and DATAPATTERN really available ?
Thx,
2013/6/18 Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca>
> Andrea: you can do something like use runtime substitution (neat example
> at
> http://linfiniti.com/2011/09/making-the-most-of-umn-mapserver-runtime-variable-substitution/),
> or MapScript WxS wrappers (
> http://mapserver.org/ogc/mapscript.html#python-examples).
> From: mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andrea Peri
> Sent: June 18, 2013 2:27 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Select the dataset at runtime
> Hi,
> Is possible to change at runtime the datasource of a layer using a
> parameter of the request to choose the dataset ?
> I'm explain better.
> I have two datasource of the same physical phenomenon.
> The first is at 96dpi and the second at 300dpi.
> I like to show the first when the user see it on a webgis and ask it using
> a request getmap with the extra parameter map_resolution=96
> Instead the mapserver should return the second dataset when the request
> has an extra_parameter map_resolution=300 tipically when the user call it
> for a print at high resolution.
> I'm trying to avoid to set two distinct mapserver layers.
> To avoid the user should change the layer in the request.
> The solution I'm searching is to allow the use of the parameter
> "map_resolution" to choose the dataset to use.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130619/f968c736/attachment.html>
