[mapserver-users] Spatialite and spatial index?
Sven Geggus
lists at fuchsschwanzdomain.de
Mon Jun 24 00:48:24 PDT 2013
Rahkonen Jukka <jukka.rahkonen at mmmtike.fi> wrote:
> GDAL has been supporting Spatialite spatial index since
> http://trac.osgeo.org/gdal/ticket/4212 Some further work was done in
> http://trac.osgeo.org/gdal/ticket/4508 I am remembering from my own
> experience that a query like the one you are using needs GDAL 1.10 but
> with that version the query should be fast. What GDAL version do you have?
1.9.0 from Debian 7.1. Unfortunately neither Debian nor Ubuntu have 1.10.x
yet and I usually don't like to manually build and install such an essential
library.
> I guess that you have already checked that you really have a valid spatial
> index with CheckSpatialIndex SQL function.
Yes, a query like this works fine and fast:
SELECT geometry,
ogc_fid,
height
FROM contours
WHERE ogc_fid IN (SELECT pkid
FROM "idx_contours_geometry"
WHERE xmax >=- 1931114.875
AND xmin <=- 1903377.5
AND ymax >= 3251495.5
AND ymin <= 3276423.5);
> I am also remembering that if a huge Spatialite table is built little by
> little for example by appending separate shapefiles into one common table
> then the result may be slow even if there is a valid spatial index because
> the SQLite data file gets so badly fragmented. Running VACUUM may have a
> great effect in such case.
I build the sqlite database directly from postgis using ogr2ogr.
I consider this spatial index thing a mapserver Issue because Index usage
seems to work to some extend using mapnik.
Sven
"Thinking of using NT for your critical apps?
Isn't there enough suffering in the world?"
(Advertisement of Sun Microsystems in Wall Street Journal)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
