[mapserver-users] build mapserver 6.2 freetype error
thomas bonfort
thomas.bonfort at gmail.com
Wed Mar 13 03:27:39 PDT 2013
don't specify the paths for libraries/dependencies that are in default
locations, i.e.
./configure --with-ogr --with-gdal --with-wfsclient --with-wmsclient
--enable-debug
--with-proj --with-gd --with-jpeg --with-freetype --with-threads
--with-wcs --with-postgis=/usr/local/database/bin/pg_config
--with-geos --with-sos
On 13 March 2013 10:35, Icadedt <icadedt at yahoo.fr> wrote:
> hi,
> im trying to build mapserver 6.2:
> i type this:
> ./configure --with-ogr=/usr/bin/gdal-config
> --with-gdal=/usr/bin/gdal-config --with-httpd=/usr/sbin/httpd
> --with-wfsclient --with-wmsclient --enable-debug
> --with-curl-config=/usr/bin/curl-config --with-proj=/usr/local --with-tiff
> --with-gd=/usr/share/locale/ --with-jpeg --with-freetype=/usr/lib64/
> --with-threads --with-wcs --with-postgis=/usr/local/database/bin/pg_config
> --with-libiconv=/usr --with-geos=/usr/local/geos-3.3.5/tools/geos-config
> --with-xml2-config=/usr/bin/xml2-config --with-sos
> but i have this error about freetype:
> checking if pkg-config path is provided... checking for pkg-config...
> /usr/bin/pkg-config
> checking for freetype-config... no
> checking for FT_Init_FreeType in -lfreetype... no
> configure: error: unable to link - reconfigure with correct
> --with-freetype=dir
> i checked freetype-2.3.11-14.el6_3.1.x86_64 is already installed
> Thanks in advance
> mapserver-users at lists.osgeo.org
