[mapserver-users] How to integrate Openlayers + MapScript C# + Postgis
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Mar 15 06:22:18 PDT 2013
Hi Marco,
This links should help:
http://mapserver.org/documentation.html -- general docs
http://mapserver.org/ogc/index.html#ogc -- WMS docs
http://mapserver.org/input/vector/postgis.html -- database access
http://mapserver.org/cgi/index.html -- CGI specific feature
-Steve
On 3/15/2013 9:16 AM, Marco Araujo wrote:
> Hello Raffaeli,
> Can you guide me on how to configure a WMS server with MapServer?
> WMS would be to prepare a file. Map with their layers? or not?
> If yes, I've already configured because I can load a map (shapefile)
> through the MapServer and visualizes it with openlayers.
> The problem is how MapServer will read data from the database and not a
> shapefile.
> Can you help me?
> Date: Fri, 15 Mar 2013 13:58:39 +0100
> From: raffaele.morelli at gmail.com
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] How to integrate Openlayers + MapScript
> C# + Postgis
> 2013/3/14 Marco Araujo <marcoaraujolsys at hotmail.com
> <mailto:marcoaraujolsys at hotmail.com>>
> Hi everybody,
> I'm trying to develop an application (ASP.NET <http://ASP.NET> C#) that gets the database
> (postgis) map through conditions "where" and process adjustments by
> mapscript and provide the map to be viewed by openlayer.
> Just setup a WMS server with mapserver and add WMS layers to openlayers.
> that's all
> You can serve any mapfile you want, just add your "where conditions"
> where you want:
> - PHP code snippet in the openlayers base page
> - use apache environment variables to serve different mapfile according
> to url request
> /L'unica speranza di catarsi, ammesso che ne esista una, resta affidata
> all'istinto di ribellione, alla rivolta non isterilita in progetti, alla
> protesta violenta e viscerale. (V. Evangelisti)
> _______________________________________________ mapserver-users mailing
> list mapserver-users at lists.osgeo.org
