[mapserver-users] How to integrate Openlayers + MapScript C# + Postgis
Marco Araujo
marcoaraujolsys at hotmail.com
Fri Mar 15 06:46:03 PDT 2013
Hello Raffaeli,
Thats right. I have already migrated shapefiles to postgis.I already developed a system for this purpose however for client / server environment.
Now I'm migrating to web platform and I'm changing the MapWindows (only client / server) by MapServer (fully web via WMS).
Let me ask one more thing:Because in my tests, my map (shapefile) when rendered by MapServer and presented in openlayer, he is shown in different squares? The more I do zoom-out, more pictures of the same map appears.
Thanks for the tips.
Date: Fri, 15 Mar 2013 14:32:19 +0100
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How to integrate Openlayers + MapScript C# + Postgis
2013/3/15 Marco Araujo <marcoaraujolsys at hotmail.com>
Hello Raffaeli,
Can you guide me on how to configure a WMS server with MapServer?WMS would be to prepare a file. Map with their layers? or not?If yes, I've already configured because I can load a map (shapefile) through the MapServer and visualizes it with openlayers.
The problem is how MapServer will read data from the database and not a shapefile.
Can you help me?
I believe you should read some fundamental documentation as Stephen suggests... your task is quite straightforward but mapserver & postgis & openlayers are not just toys :-)
-r
PS as second step, if you have a working mapfile (as you stated) you should load shp file into postgis and add a postgis layer in your mapfile
L'unica speranza di catarsi, ammesso che ne esista una,
resta affidata all'istinto di ribellione, alla rivolta non isterilita
in progetti, alla protesta violenta e viscerale. (V. Evangelisti)
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130315/1b8cbbea/attachment.html>
