[mapserver-users] mapserver issues...(new user)
Mark Mirrlees
mmirrlees at hotmail.com
Fri Mar 15 14:58:43 PDT 2013
Hi all, I'm a new user to mapserver and having some issues with the mapfile that I have created from QGIS. Basically I am trying to create a map of Canada with major cities, highways, expressways, province names. The map outputs fine but when I change anything in the mapfile it doesnt work. I need to change the projection to a Lambert Conformal Conic, be able to display the highways if the layer is visible, the highways being only visible if zoomed in past 1:2500000, provinces labeled with the calibri font. For the major cities, I want to use a S3 symbol (green star) found in a symbol folder where all of the data is located while using the symbols.sty style sheet while only visible past 1:2500000 and labeled when zoomed in past 1:1000000. When I click any of the checkboxes that I created to help zoom in or out they work fine but when I click any of the checkboxes for the cities, provinces, roads etc it doesnt load. Here is my mapfile in green so I can seperate the text better. # Map file created from QGIS project file C:/wwwroot/M_Mirrlees_Assign3/markassign3.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "QGIS-MAP"
# Map image size
SIZE 500 500
UNITS meters EXTENT -143.210462 39.001401 -50.461045 85.911094
FONTSET "/wwwroot/fonts/fontset.txt"
SYMBOLSET "/wwwroot/symbols/symbols.sty"
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END # Background color for the map canvas -- change as desired
IMAGECOLOR 0 0 255
IMAGEQUALITY 95
IMAGETYPE agg OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END # Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH "/ms4w/tmp/ms_tmp/" # Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL "/ms_tmp/" # WMS server settings
METADATA
'ows_title' 'QGIS-MAP'
'ows_onlineresource' 'localhost.com/cgi-bin/mapserv.exe?map=C:/wwwroot/M_Mirrlees_Assign3/global.map'
'ows_srs' 'EPSG:4326'
END #Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'C:/wwwroot/M_Mirrlees_Assign3/global.html'
END
SCALEBAR
STATUS EMBED
UNITS KILOMETERS
INTERVALS 3
TRANSPARENT TRUE
OUTLINECOLOR 0 0 0
END # End for scalebar
LAYER
NAME 'province_dd'
TYPE POLYGON
DUMP false
DATA '../data/province_dd.shp'
METADATA
'ows_title' 'province_dd'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASSITEM 'NAME_ENG'
CLASS
NAME "default"
EXPRESSION ""
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 30 158 173
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Alberta"
EXPRESSION "Alberta"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 103 48 123
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = British Columbia"
EXPRESSION "British Columbia"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 157 204 18
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Manitoba"
EXPRESSION "Manitoba"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 132 187 236
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = New Brunswick"
EXPRESSION "New Brunswick"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 190 235 139
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Newfoundland"
EXPRESSION "Newfoundland"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 135 148 47
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Northwest Territories"
EXPRESSION "Northwest Territories"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 73 51 112
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Nova Scotia"
EXPRESSION "Nova Scotia"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 94 79 203
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Nunavut"
EXPRESSION "Nunavut"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 116 114 31
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Ontario"
EXPRESSION "Ontario"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 254 137 86
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Prince Edward Island"
EXPRESSION "Prince Edward Island"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 117 170 97
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Quebec"
EXPRESSION "Quebec"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 150 81 98
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Saskatchewan"
EXPRESSION "Saskatchewan"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 6 73 91
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
CLASS
NAME "NAME_ENG = Yukon Territory"
EXPRESSION "Yukon Territory"
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 223 168 55
END
LABEL
FONT arial
TYPE truetype
SIZE 8
COLOR 0 0 0
ANGLE 0
POSITION cc
FORCE false
ANTIALIAS false
PARTIALS false
END
END
END LAYER
NAME 'mjrroads'
TYPE LINE
DUMP false
DATA '../data/mjrroads.shp'
METADATA
'ows_title' 'mjrroads'
END
STATUS DEFAULT
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASSITEM 'TYPE'
CLASS
NAME "default"
EXPRESSION ""
STYLE
WIDTH 0.91
COLOR 201 157 32
END
END
CLASS
NAME "TYPE = Expressway"
EXPRESSION "Expressway"
STYLE
WIDTH 7.0
COLOR 255 0 0
END
END
CLASS
NAME "TYPE = Primary Highway"
EXPRESSION "Primary Highway"
STYLE
WIDTH 3.5
COLOR 0 0 0
END
END
END LAYER
NAME 'mjcities'
TYPE POINT
DUMP false
DATA '../data/mjcities.shp'
METADATA
'ows_title' 'mjcities'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'mjcities'
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 182 109 194
END
END
ENDEND As mentioned before I am fairly new at this (but want to learn the process) but not sure what to do as everytime I change something the map doesnt display correctly! Any help would be greatly appreciated. Thanks,Mark
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130315/c9388a08/attachment-0001.html>
