[mapserver-users] label issues...
Yves Jacolin
yjacolin at free.fr
Mon Mar 18 13:03:39 PDT 2013
Hello,
You should use also LABELMAXSCALE instead of MAXSCALE.
Y.
Le lundi 18 mars 2013 15:59:41 Mark Mirrlees a écrit :
> Ok so I want to stick this code into the .map file... where should it be
> placed in the section that i bolded? LABEL COLOR 255 255 255
> FONT "arial"
> TYPE "truetype"
> SIZE 10
> ANGLE 0
> POSITION cc
> FORCE false
> ANTIALIAS false
> PARTIALS false
> END
> Thanks,MarkFrom: David.Fawcett at state.mn.us
> To: mmirrlees at hotmail.com; mapserver-users at lists.osgeo.org
> Subject: RE: [mapserver-users] label issues...
> Date: Mon, 18 Mar 2013 19:51:42 +0000
> Mark,
> You will want to add a LABEL block to your mapfile.
> http://mapserver.org/mapfile/label.html
> I would also comment out the maxscale until you get the labels working.
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Mirrlees
> Sent: Monday, March 18, 2013 2:48 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] label issues...
> Hi all,
> Ok so now I have a new problem with the labeling.
> I would like to get my labels to start showing up at a scale of 1:1000000
> but nothing is working...
> here is a snippet of my mapfile...
> LAYER
> NAME 'mjcities'
> TYPE POINT
> DUMP false
> EXTENT -143.210462 39.001401 -50.461045 85.911094
> DATA '../data/mjcities.shp'
> METADATA
> 'ows_title' 'mjcities'
> END
> STATUS default
> MAXSCALE 1000000
> TRANSPARENCY 100
> CLASSITEM 'NAME'
> LABELITEM 'NAME'
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> NAME 'mjcities'
> STYLE
> SYMBOL "circle"
> SIZE 15.0
> OUTLINECOLOR 0 0 0
> COLOR 182 109 194
> END
> Thanks,
> Mark
Yves Jacolin
