[mapserver-users] CLUSTER - Average Value
Tamas Szekeres
szekerest at gmail.com
Fri Mar 22 08:21:22 PDT 2013
May be I misunderstood something, but the requirement of "style the
clusters a different colour depending on the calculation of that
expression" requires only one class per expression condition.
Tamas
2013/3/22 thomas bonfort <thomas.bonfort at gmail.com>
> Unless the cluster introduced some new codepaths in the rendering
> chain, I do not think this is the case. Only a *single* class gets
> used per rendered feature (the first one matching all expression and
> min/maxscale constraints)
> thomas
> On 22 March 2013 14:59, Tamas Szekeres <szekerest at gmail.com> wrote:
> > I think adding multiple classes to the clustered layer (with multiple
> > expressions regarding to the intervals) should do the job.
> > Best regards,
> > Tamas
> > 2013/3/22 Mark Davidson <mark at 4each.co.uk>
> >> That works great thanks Tamas. I'm now trying to use that expression as
> a
> >> condition on a class.
> >> I'm trying to style the clusters a different colour depending on the
> >> calculation of that expression. Can multiple styles be applied to a
> single
> >> cluster point?
> >> CLASS
> >> NAME "Clustered Point"
> >> EXPRESSION ("[Cluster:FeatureCount]" != "1")
> >> STYLE
> >> SIZE 22
> >> SYMBOL "circle"
> >> COLOR 255 0 0
> >> END
> >> LABEL
> >> TEXT ([Sum:lowesttemperature]/[Count:lowesttemperature])
> >> FONT "arial"
> >> TYPE truetype
> >> SIZE 8
> >> COLOR 255 255 255
> >> END
> >> END
> >> CLASS
> >> EXPRESSION (([Sum:lowesttemperature]/[Count:lowesttemperature]) >
> 1)
> >> STYLE
> >> SYMBOL "circle"
> >> COLOR 0 255 0
> >> END
> >> END
> >> On 22 March 2013 13:15, Tamas Szekeres <szekerest at gmail.com> wrote:
> >>> Mark,
> >>> I think LABEL level expressions would work in this case. Something
> like:
> >>> LABEL
> >>> TEXT ([Sum:itemname]/[Count:itemname])
> >>> TYPE TRUETYPE
> >>> END
> >>> Best regards,
> >>> Tamas
> >>>> Hi All,
> >>>> I'm new to using mapserver and have been implementing a WMS overlay
> >>>> using the CLUSTER funcionality got pretty much everything I need
> working,
> >>>> but I can't seem to get an average value of a cluster to use as part
> of the
> >>>> styling and labelling.
> >>>> I've tried everything I can think of to try and get it working but am
> >>>> having no luck. I thought that since you can do [Max:itemname] and
> >>>> [Count:itemname] I would be able to do an equation to work out the
> average,
> >>>> but I just get syntax errors with everything I try and haven't been
> able to
> >>>> find any examples of doing this.
> >>>> Could anyone tell me if its possible to do this? And if so provide an
> >>>> example?
> >>>> Any input would be very much appreciated,
> >>>> Thanks,
> >>>> Mark Davidson
> >>>> _______________________________________________
> >>>> mapserver-users mailing list
> >>>> mapserver-users at lists.osgeo.org
> >>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130322/26f131cc/attachment.html>
