[mapserver-users] FW: problem with legend images
thomas bonfort thomas.bonfort at gmail.com
Wed Nov 20 02:15:41 PST 2013
Worth,
this is happening because you are using scale-dependant rendering, but
the legend requests are scale independant. You should be able to
overcome this by adding your wanted scale to a SCALE=xxx url
parameter, or you can rewrite your mapfile by playing with your
layer's SYMBOLSCALEDENOM and setting your style widths to something
more pleasing for your legend output, e.g.
SYMBOLSCALEDENOM 1000
WIDTH 10
is equivalent in map outputs to
SYMBOLSCALEDENOM 10000
WIDTH 1
whereas the first will produce 10 pixel wide lines in the legend by
defaut vs. 1 pixel wide lines for the second.
regards,
thomas
On 18 November 2013 18:08, Worth Lutz <wal3 at mindspring.com> wrote:
> Hi all,
> I am having a problem generating my legend. I have roads which look gook on
> my map but the legend images generated are not what I expected.
> Attached is a picture of a portion of my map and the legend.
> Each piece of the legend is retrieved with a "getLegendGraphic" call.
> Has any one else run into this problem with "exploded" legends?
> Here is one of my classes:
>   CLASS
>     NAME "Interstate Highways"
>     #MAXSCALEDENOM 3000010
>     MINSCALEDENOM 999
>     EXPRESSION "I" # Interstates
>     STYLE
>       COLOR 121 0 255
>       WIDTH 35
>       MINWIDTH 2
>       MAXWIDTH 35
>     END
>     STYLE
>       COLOR 181 51 51
>       WIDTH 33
>       MINWIDTH 0
>       MAXWIDTH 31
>     END
>   END
> I get what I was looking for on map but have not figured out how to get the
> legend to work.
> My entire layer definition is show below:
> LAYER
>   NAME "NCDOT-roads"
>   GROUP "NCDOT_transportation_group"
>   STATUS off
>   METADATA
>     wms_title           "NCDOT-Roads"
>     wms_srs             "EPSG:2264"
>   END
>   TYPE line
>   UNITS pixels
>   DATA NCDOT/shapefiles/LRS_ARCS
>   PROJECTION
>     "init=epsg:2264" # NAD 83 North Carolina (ftUS)
>   END
>   MINSCALEDENOM 999
>   TEMPLATE void
>   CLASSITEM "rte_1_clss"
>   CLASS
>     MINSCALEDENOM 999
>     STYLE
>       COLOR 121 0 255
>       WIDTH 35
>       MINWIDTH 2
>       MAXWIDTH 35
>     END
>     STYLE
>       COLOR 181 51 51
>       WIDTH 33
>       MINWIDTH 0
>       MAXWIDTH 31
>     END
>   END
>   CLASS
>     NAME "US Highways"
>     EXPRESSION "US" # US Highways
>     MINSCALEDENOM 999
>     STYLE
>       COLOR 121 121 0
>       WIDTH 35
>       MINWIDTH 2
>       MAXWIDTH 35
>     END
>     STYLE
>       COLOR 181 181 0
>       WIDTH 31
>       MINWIDTH 0
>       MAXWIDTH 31
>     END
>   END
>   CLASS
>     NAME "NC Highways"
>     EXPRESSION "NC" # NC Highways
>     MAXSCALEDENOM 800001
>     MINSCALEDENOM 999
>     STYLE
>       COLOR 181 181 0
>       WIDTH 22
>       MINWIDTH 2
>       MAXWIDTH 22
>     END
>   END
>   CLASS
>     NAME "State Roads"
>     EXPRESSION "SR"   # State Roads
>     MAXSCALEDENOM 70001
>     MINSCALEDENOM 985
>     STYLE
>       COLOR 181 181 0
>       WIDTH 22
>       MINWIDTH 1
>       MAXWIDTH 22
>     END
>   END
>   CLASS
>     NAME "highway ramps"
>     MAXSCALEDENOM 30001
>     EXPRESSION "RMP" # HWY ramps
>     STYLE
>       COLOR 121 121 0
>       WIDTH 30
>       MINWIDTH 1
>       MAXWIDTH 24
>     END
>     STYLE
>       COLOR 181 181 0
>       WIDTH 28
>       MINWIDTH 0
>       MAXWIDTH 20
>     END
>   END
> END # NCDOT-roads
> mapserver-users at lists.osgeo.org
