[mapserver-users] Expression segmentation fault
thomas bonfort
thomas.bonfort at gmail.com
Wed Sep 4 05:33:24 PDT 2013
Frank, please supply a backtrace of the crash (`bt` in gdb once it has
halted at the segfault)
thomas
On Wed, Sep 4, 2013 at 2:25 PM, Frank Broniewski <brfr at metrico.lu> wrote:
> Hi,
> I just updated my mapserver installation to the latest version (6.2.1). I'm
> running FreeBSD 9.1 and I'm getting a segmentation fault related to
> expression usage in my mapfile. I've already compiled mapserver with debug
> symbols and I loaded the core file into gdb:
>> gdb /usr/local/www/apache22/cgi-bin/mapserv mapserv.core
> <snip>
> Reading symbols from /lib/libc.so.7...done.
> Loaded symbols for /lib/libc.so.7
> Reading symbols from /usr/local/lib/libintl.so.9...done.
> Loaded symbols for /usr/local/lib/libintl.so.9
> Reading symbols from /usr/lib/libsupc++.so.1...done.
> Loaded symbols for /usr/lib/libsupc++.so.1
> Reading symbols from /libexec/ld-elf.so.1...done.
> Loaded symbols for /libexec/ld-elf.so.1
> #0 0x00000008008e2520 in yylex (lvalp=0x7fffffffd250, p=0x7fffffffd3b0) at
> mapparser.y:649
> 649 mapparser.y: No such file or directory.
> in mapparser.y
> [New Thread 809007400 (LWP 101134/mapserv)]
> So apparently there seems to be a file missing!? Looking at the source code
> (git), line 649 is a blank line, so I'm not sure what's missing exactly.
> I've got yacc, bison and flex installed. For testing purposes I'm using the
> mapserver cgi on the command line:
> /usr/local/www/apache22/cgi-bin/mapserv -nh
> "QUERY_STRING=map=/data/web/mapserver/cnra/cnra.map&mode=map&layer=boundaries"
> The boundaries layer:
> Layer
> # Classitem "level"
> Connection "host=10.0.0.2 dbname=osm user=user password=guessme"
> Connectiontype Postgis
> Data "geom FROM (SELECT osm_id, way AS geom, name, admin_level AS level,
> tags FROM planet_osm_polygon) AS foo USING UNIQUE osm_id USING SRID=3857"
> Filter "tags ?& ARRAY['boundary', 'admin_level']"
> Name "boundaries"
> Processing "CLOSE_CONNECTION=DEFER"
> Status on
> Type line
> Units meters
> Metadata
> "ows_title" "Boundary Map"
> "ows_abstract" "Boundary map - data from OpenStreetMap, ODbl
> licensed"
> End
> Projection
> "init=epsg:3857"
> End
> Class
> Expression ("[level]" = "6")
> # Expression "6"
> Name "communes"
> Style
> Color 10 10 10
> Opacity 50
> Width 2
> End
> End
> End
> The classitem / simple expression (Expression "6") works with the mapserver
> cgi, but python mapscript throws an error: _mapscript.MapServerError:
> msEvalExpression(): General error message. Invalid item index.
> I've read the mapserver expressions documentation [1] and the note that says
> something about the working environment might be linked to more than one
> expression library. But my operating system skills are not high enough to
> turn this paragraph into something useful for me.
> So any help is greatly appreciated.
> Frank
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> technologies d'information géographique
> rue des Romains 36
> L-5433 NIEDERDONVEN
> tél.: +352 26 74 94 - 28
> fax.: +352 26 74 94 99
> http://www.metrico.lu
> mapserver-users at lists.osgeo.org
