[mapserver-users] Expression segmentation fault
thomas bonfort
thomas.bonfort at gmail.com
Fri Sep 6 01:16:27 PDT 2013
Frank,
can you try without including the hstore tags in your select?
thomas
On Thu, Sep 5, 2013 at 3:49 PM, Frank Broniewski <brfr at metrico.lu> wrote:
> Ok, this is weird. It is, as I know now, data source related. I was poking
> in the layer configuration to find out why the core dump happens.
> Reinstalling didn't solve the issue, btw.
> So first I converted the data to shapefile with ogr2ogr (as always very
> handy!) and changed the layer accordingly. And no core dump happened!
> Then I tried several versions of the data and filter statements without
> success.
> Since this is a osm2pgsql database I swapped finally the table from
> planet_osm_polygon to planet_osm_line (same table schema apart from the
> geometry) - and voilà - no core dump.
> So I can relate the problem to the planet_osm_polygon table - but I'm not
> sure what difference actually is responsible for the crash ...
> The most apparent difference is of course the geometry type: planet_osm_line
> is linestring, planet_osm_polygon is geometry ...
> I will investigate the attributes further tomorrow, but now I need to earn
> some money. It's always the deadlines ...
> Frank
> Am 2013-09-05 09:47, schrieb thomas bonfort:
>> Frank,
>> This is such a simple use-case that I doubt it's a bug in the code
>> per-se. Can you make sure that you are using a clean build (make clean
>> && make && make install) as I suspect this could be happening due to a
>> compilation problem (as a rule of thumb, with mapserver <6.4, always
>> run make clean after re-running configure)
>> thomas
>> On Wed, Sep 4, 2013 at 2:39 PM, Frank Broniewski <brfr at metrico.lu> wrote:
>>> Am 2013-09-04 14:33, schrieb thomas bonfort:
>>>> Frank, please supply a backtrace of the crash (`bt` in gdb once it has
>>>> halted at the segfault)
>>>> thomas
>>>> On Wed, Sep 4, 2013 at 2:25 PM, Frank Broniewski <brfr at metrico.lu>
>>>> wrote:
>>>>> Hi,
>>>>> I just updated my mapserver installation to the latest version (6.2.1).
>>>>> I'm
>>>>> running FreeBSD 9.1 and I'm getting a segmentation fault related to
>>>>> expression usage in my mapfile. I've already compiled mapserver with
>>>>> debug
>>>>> symbols and I loaded the core file into gdb:
>>>>>> gdb /usr/local/www/apache22/cgi-bin/mapserv mapserv.core
>>>>> <snip>
>>>>> Reading symbols from /lib/libc.so.7...done.
>>>>> Loaded symbols for /lib/libc.so.7
>>>>> Reading symbols from /usr/local/lib/libintl.so.9...done.
>>>>> Loaded symbols for /usr/local/lib/libintl.so.9
>>>>> Reading symbols from /usr/lib/libsupc++.so.1...done.
>>>>> Loaded symbols for /usr/lib/libsupc++.so.1
>>>>> Reading symbols from /libexec/ld-elf.so.1...done.
>>>>> Loaded symbols for /libexec/ld-elf.so.1
>>>>> #0 0x00000008008e2520 in yylex (lvalp=0x7fffffffd250,
>>>>> p=0x7fffffffd3b0)
>>>>> at
>>>>> mapparser.y:649
>>>>> 649 mapparser.y: No such file or directory.
>>>>> in mapparser.y
>>>>> [New Thread 809007400 (LWP 101134/mapserv)]
>>>>> So apparently there seems to be a file missing!? Looking at the source
>>>>> code
>>>>> (git), line 649 is a blank line, so I'm not sure what's missing
>>>>> exactly.
>>>>> I've got yacc, bison and flex installed. For testing purposes I'm using
>>>>> the
>>>>> mapserver cgi on the command line:
>>>>> /usr/local/www/apache22/cgi-bin/mapserv -nh
>>>>> "QUERY_STRING=map=/data/web/mapserver/cnra/cnra.map&mode=map&layer=boundaries"
>>>>> The boundaries layer:
>>>>> Layer
>>>>> # Classitem "level"
>>>>> Connection "host=10.0.0.2 dbname=osm user=user password=guessme"
>>>>> Connectiontype Postgis
>>>>> Data "geom FROM (SELECT osm_id, way AS geom, name, admin_level AS
>>>>> level,
>>>>> tags FROM planet_osm_polygon) AS foo USING UNIQUE osm_id USING
>>>>> SRID=3857"
>>>>> Filter "tags ?& ARRAY['boundary', 'admin_level']"
>>>>> Name "boundaries"
>>>>> Processing "CLOSE_CONNECTION=DEFER"
>>>>> Status on
>>>>> Type line
>>>>> Units meters
>>>>> Metadata
>>>>> "ows_title" "Boundary Map"
>>>>> "ows_abstract" "Boundary map - data from OpenStreetMap, ODbl
>>>>> licensed"
>>>>> End
>>>>> Projection
>>>>> "init=epsg:3857"
>>>>> End
>>>>> Class
>>>>> Expression ("[level]" = "6")
>>>>> # Expression "6"
>>>>> Name "communes"
>>>>> Style
>>>>> Color 10 10 10
>>>>> Opacity 50
>>>>> Width 2
>>>>> End
>>>>> End
>>>>> End
>>>>> The classitem / simple expression (Expression "6") works with the
>>>>> mapserver
>>>>> cgi, but python mapscript throws an error: _mapscript.MapServerError:
>>>>> msEvalExpression(): General error message. Invalid item index.
>>>>> I've read the mapserver expressions documentation [1] and the note that
>>>>> says
>>>>> something about the working environment might be linked to more than
>>>>> one
>>>>> expression library. But my operating system skills are not high enough
>>>>> to
>>>>> turn this paragraph into something useful for me.
>>>>> So any help is greatly appreciated.
>>>>> Frank
>>>>> Frank BRONIEWSKI
>>>>> METRICO s.à r.l.
>>>>> géomètres
>>>>> technologies d'information géographique
>>>>> rue des Romains 36
>>>>> L-5433 NIEDERDONVEN
>>>>> tél.: +352 26 74 94 - 28
>>>>> fax.: +352 26 74 94 99
>>>>> http://www.metrico.lu
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Hi Thomas,
>>> thanks for the fast response! Here's the bt:
>>> (gdb) bt
>>> #0 0x00000008008e2520 in yylex (lvalp=0x7fffffffd250, p=0x7fffffffd3b0)
>>> at
>>> mapparser.y:649
>>> #1 0x00000008008e0146 in yyparse (p=0x7fffffffd3b0) at mapparser.c:1500
>>> #2 0x00000008009239b2 in msEvalExpression (layer=0x809009000,
>>> shape=0x7fffffffd4e0,
>>> expression=0x8090a0280, itemindex=-1) at maputil.c:478
>>> #3 0x0000000800923f03 in msShapeGetClass (layer=0x809009000,
>>> map=0x8090bd800,
>>> shape=0x7fffffffd4e0, classgroup=0x0, numclasses=1) at maputil.c:581
>>> #4 0x0000000800980ab2 in msDrawVectorLayer (map=0x8090bd800,
>>> layer=0x809009000, image=0x8090a91c0)
>>> at mapdraw.c:989
>>> #5 0x00000008009800ed in msDrawLayer (map=0x8090bd800,
>>> layer=0x809009000,
>>> image=0x8090a91c0)
>>> at mapdraw.c:808
>>> #6 0x000000080097ed18 in msDrawMap (map=0x8090bd800, querymap=0) at
>>> mapdraw.c:437
>>> #7 0x0000000800a16e6e in msCGIDispatchImageRequest (mapserv=0x8090b2300)
>>> at
>>> mapservutil.c:1448
>>> #8 0x0000000800a179c2 in msCGIDispatchRequest (mapserv=0x8090b2300) at
>>> mapservutil.c:1690
>>> #9 0x00000000004012c1 in main (argc=3, argv=0x7fffffffd9f0) at
>>> mapserv.c:259
>>> (gdb)
>>> Frank BRONIEWSKI
>>> METRICO s.à r.l.
>>> géomètres
>>> rue des Romains 36
>>> L-5433 NIEDERDONVEN
> Frank BRONIEWSKI
> METRICO s.à r.l.
> géomètres
> rue des Romains 36
> L-5433 NIEDERDONVEN
