[mapserver-users] Expression segmentation fault
Frank Broniewski
brfr at metrico.lu
Mon Sep 9 07:38:16 PDT 2013
Hi Thomas,
I tried your patch and it worked! Thanks alot. As requested, I've
created an issue here [1].
I agree with you that this issue is a bit strange, because it only
occurs when you use an expression with the layer, without the expression
the segfault wouldn't happen ...
thanks again,
Frank
[1] https://github.com/mapserver/mapserver/issues/4751
Am 2013-09-06 16:40, schrieb thomas bonfort:
> Frank,
> I'm able to reproduce this with a geometrycollection empty. What's
> strange is I was obliged to force postgis to return the feature, as
> the bounding box where clause was filtering it out and it was
> therefore never returned to mapserver.
> I'll come up with a patch soon, would you mind opening an issue for this please?
> thanks,
> thomas
> On Fri, Sep 6, 2013 at 2:20 PM, Frank Broniewski <brfr at metrico.lu> wrote:
>> Ok, so I did a little bit of geometry testing. Don't know why that should
>> cause an expression crash, but well ...
>> here's the query I ran on planet_osm_line and planet_osm_polygon in PostGIS:
>> select
>> osm_id, boundary, admin_level, tags,
>> st_isvalid(way) as isvalid,
>> st_isvalidreason(way) as reason,
>> st_isclosed(way) as isclosed,
>> st_isempty(way) as isempty,
>> st_geometrytype(way) as geometrytype,
>> st_length(way) as length,
>> st_perimeter(way) as perimeter,
>> st_numgeometries(way) as numgeometries,
>> st_numinteriorrings(way) as numinteriorrings,
>> st_astext(way) as wkt
>> from planet_osm_polygon
>> where way && st_transform(st_setsrid('BOX3D(0 0, 150000 200000)'::box3d,
>> 2169), 3857)
>> and tags ?& ARRAY['boundary', 'admin_level']
>> order by geometrytype, admin_level, name
>> There's one record that differs from the rest in the planet_osm_polygon
>> table. I've pasted the result below. It has a geometrytype of
>> GEOMETRYCOLLECTION and is empty, so that may cause a crash ...
>> 229382895;"administrative";"8";""area"=>"yes", "name"=>"RW 10",
>> "boundary"=>"administrative", "admin_level"=>"8", "flood_prone"=>"no",
>> "is_in:hamlet"=>"MENTENG DALAM", "is_in:district"=>"Jakarta Selatan",
>> "is_in:province"=>"DKI Jakarta", "is_in:subdistrict"=>"TEBET"";t;"Valid
>> Geometry";;t;"ST_GeometryCollection";0;0;0;;"GEOMETRYCOLLECTION EMPTY"
>> The attributes confirm, that this record could be a remain of
>> http://www.openstreetmap.org/browse/way/229382895 , but I really wonder why
>> it gets caught in the bbox which should center around Luxembourg with parts
>> of the surrounding countries. But when the geometry is a black hole you
>> never know :-)
>> Am 2013-09-05 16:30, schrieb Stephen Woodbridge:
>>> Hi,
>>> This is a great idea. Regardless we should try to identify the case that
>>> is causing the crash and trap that. Mapserver should never crash as a
>>> general rule so finding the specific case is important so Thomas can
>>> reproduce it.
>>> If you have (or can load) the data in a database table, then it should
>>> be fairly easy to do a manual binary search to find the offending object
>>> by adding " where gid between <lower> and <upper>" to your query and
>>> adjusting the value of lower and upper to narrow the search to the
>>> problem object.
>>> Thanks,
>>> -Steve W
>>> On 9/5/2013 10:11 AM, Rahkonen Jukka wrote:
>>>> Hi,
>>>> Osm2pgsql can create invalid polygons with self-intersections and/or
>>>> three-vertex A-B-A rings. It might be good to run MakeValid or simply
>>>> find possibly invalid features with IsValid and delete them and then
>>>> see if Mapserver gets happy. Actually, run IsValid and save the
>>>> faulty geometries somewhere before correcting or deleting them. It
>>>> would be nice to catch them if they happen to be the reason for the
>>>> crash.
>>>> -Jukka Rahkonen-
>>>> Frank Broniewski wrote:
>>>>> Ok, this is weird. It is, as I know now, data source related. I was
>>>>> poking in the layer configuration to find out why the core dump
>>>>> happens. Reinstalling didn't solve the issue, btw.
>>>>> So first I converted the data to shapefile with ogr2ogr (as always
>>>>> very handy!) and changed the layer accordingly. And no core dump
>>>>> happened! Then I tried several versions of the data and filter
>>>>> statements without success. Since this is a osm2pgsql database I
>>>>> swapped finally the table from planet_osm_polygon to
>>>>> planet_osm_line (same table schema apart from the geometry) - and
>>>>> voilà - no core dump.
>>>>> So I can relate the problem to the planet_osm_polygon table - but
>>>>> I'm not sure what difference actually is responsible for the crash
>>>>> The most apparent difference is of course the geometry type:
>>>>> planet_osm_line is linestring, planet_osm_polygon is geometry ...
>>>>> I will investigate the attributes further tomorrow, but now I need
>>>>> to earn some money. It's always the deadlines ...
>>>>> Frank
>>>>> Am 2013-09-05 09:47, schrieb thomas bonfort:
>>>>>> Frank, This is such a simple use-case that I doubt it's a bug in
>>>>>> the code per-se. Can you make sure that you are using a clean
>>>>>> build (make clean && make && make install) as I suspect this
>>>>>> could be happening due to a compilation problem (as a rule of
>>>>>> thumb, with mapserver <6.4, always run make clean after
>>>>>> re-running configure)
>>>>>> -- thomas
>>>>>> On Wed, Sep 4, 2013 at 2:39 PM, Frank Broniewski
>>>>>>> Am 2013-09-04 14:33, schrieb thomas bonfort:
>>>>>>>> Frank, please supply a backtrace of the crash (`bt` in gdb
>>>>>>>> once it has halted at the segfault)
>>>>>>>> -- thomas
>>>>>>>> On Wed, Sep 4, 2013 at 2:25 PM, Frank Broniewski
>>>>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I just updated my mapserver installation to the latest
>>>>>>>>> version (6.2.1). I'm running FreeBSD 9.1 and I'm getting a
>>>>>>>>> segmentation fault related to expression usage in my
>>>>>>>>> mapfile. I've already compiled mapserver with debug symbols
>>>>>>>>> and I loaded the core file into gdb:
>>>>>>>>>> gdb /usr/local/www/apache22/cgi-bin/mapserv mapserv.core
>>>>>>>>> <snip> Reading symbols from /lib/libc.so.7...done. Loaded
>>>>>>>>> symbols for /lib/libc.so.7 Reading symbols from
>>>>>>>>> /usr/local/lib/libintl.so.9...done. Loaded symbols for
>>>>>>>>> /usr/local/lib/libintl.so.9 Reading symbols from
>>>>>>>>> /usr/lib/libsupc++.so.1...done. Loaded symbols for
>>>>>>>>> /usr/lib/libsupc++.so.1 Reading symbols from
>>>>>>>>> /libexec/ld-elf.so.1...done. Loaded symbols for
>>>>>>>>> /libexec/ld-elf.so.1 #0 0x00000008008e2520 in yylex
>>>>>>>>> (lvalp=0x7fffffffd250, p=0x7fffffffd3b0) at
>>>>>>>>> mapparser.y:649 649 mapparser.y: No such file or
>>>>>>>>> directory. in mapparser.y [New Thread 809007400 (LWP
>>>>>>>>> 101134/mapserv)]
>>>>>>>>> So apparently there seems to be a file missing!? Looking at
>>>>>>>>> the source code (git), line 649 is a blank line, so I'm not
>>>>>>>>> sure what's missing exactly. I've got yacc, bison and flex
>>>>>>>>> installed. For testing purposes I'm using the mapserver cgi
>>>>>>>>> on the command line:
>>>>>>>>> /usr/local/www/apache22/cgi-bin/mapserv -nh
>>>>> "QUERY_STRING=map=/data/web/mapserver/cnra/cnra.map&mode=map&laye
>>>>> r=boundaries"
>>>>>>>>> The boundaries layer:
>>>>>>>>> Layer
>>>>>>>>> # Classitem "level" Connection "host=10.0.0.2 dbname=osm
>>>>>>>>> user=user
>>>>> password=guessme"
>>>>>>>>> Connectiontype Postgis Data "geom FROM (SELECT osm_id, way
>>>>>>>>> AS geom, name, admin_level
>>>>> AS
>>>>>>>>> level, tags FROM planet_osm_polygon) AS foo USING UNIQUE
>>>>>>>>> osm_id USING
>>>>> SRID=3857"
>>>>>>>>> Filter "tags ?& ARRAY['boundary', 'admin_level']" Name
>>>>>>>>> "boundaries" Processing "CLOSE_CONNECTION=DEFER" Status on
>>>>>>>>> Type line Units meters
>>>>>>>>> Metadata "ows_title" "Boundary Map" "ows_abstract"
>>>>>>>>> "Boundary map - data from OpenStreetMap, ODbl licensed"
>>>>>>>>> End
>>>>>>>>> Projection "init=epsg:3857" End
>>>>>>>>> Class
>>>>>>>>> Expression ("[level]" = "6") # Expression "6" Name
>>>>>>>>> "communes"
>>>>>>>>> Style Color 10 10 10 Opacity 50 Width 2 End
>>>>>>>>> End End
>>>>>>>>> The classitem / simple expression (Expression "6") works
>>>>>>>>> with the mapserver cgi, but python mapscript throws an
>>>>>>>>> error: _mapscript.MapServerError: msEvalExpression():
>>>>>>>>> General error message. Invalid item index.
>>>>>>>>> I've read the mapserver expressions documentation [1] and
>>>>>>>>> the note that says something about the working environment
>>>>>>>>> might be linked to more than
>>>>> one
>>>>>>>>> expression library. But my operating system skills are not
>>>>>>>>> high enough to turn this paragraph into something useful
>>>>>>>>> for me.
>>>>>>>>> So any help is greatly appreciated.
>>>>>>>>> Frank
>>>>>>>>> Frank BRONIEWSKI
>>>>>>>>> METRICO s.à r.l. géomètres technologies d'information
>>>>>>>>> géographique rue des Romains 36 L-5433 NIEDERDONVEN
>>>>>>>>> tél.: +352 26 74 94 - 28 fax.: +352 26 74 94 99
>>>>>>>>> http://www.metrico.lu
>>>>>>>>> _______________________________________________
>>>>>>>>> mapserver-users mailing list
>>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>>>> Hi Thomas,
>>>>>>> thanks for the fast response! Here's the bt:
>>>>>>> (gdb) bt
>>>>>>> #0 0x00000008008e2520 in yylex (lvalp=0x7fffffffd250,
>>>>>>> p=0x7fffffffd3b0) at mapparser.y:649 #1 0x00000008008e0146 in
>>>>>>> yyparse (p=0x7fffffffd3b0) at mapparser.c:1500 #2
>>>>>>> 0x00000008009239b2 in msEvalExpression (layer=0x809009000,
>>>>>>> shape=0x7fffffffd4e0, expression=0x8090a0280, itemindex=-1) at
>>>>>>> maputil.c:478 #3 0x0000000800923f03 in msShapeGetClass
>>>>>>> (layer=0x809009000, map=0x8090bd800, shape=0x7fffffffd4e0,
>>>>>>> classgroup=0x0, numclasses=1) at maputil.c:581 #4
>>>>>>> 0x0000000800980ab2 in msDrawVectorLayer (map=0x8090bd800,
>>>>>>> layer=0x809009000, image=0x8090a91c0) at mapdraw.c:989 #5
>>>>>>> 0x00000008009800ed in msDrawLayer (map=0x8090bd800,
>>>>> layer=0x809009000,
>>>>>>> image=0x8090a91c0) at mapdraw.c:808 #6 0x000000080097ed18 in
>>>>>>> msDrawMap (map=0x8090bd800, querymap=0)
>>>>> at
>>>>>>> mapdraw.c:437 #7 0x0000000800a16e6e in
>>>>>>> msCGIDispatchImageRequest
>>>>> (mapserv=0x8090b2300) at
>>>>>>> mapservutil.c:1448 #8 0x0000000800a179c2 in
>>>>>>> msCGIDispatchRequest (mapserv=0x8090b2300)
>>>>> at
>>>>>>> mapservutil.c:1690 #9 0x00000000004012c1 in main (argc=3,
>>>>>>> argv=0x7fffffffd9f0) at mapserv.c:259 (gdb)
>>>>>>> -- Frank BRONIEWSKI
>>>>> -- Frank BRONIEWSKI
>>>>> METRICO s.à r.l. géomètres technologies d'information géographique
>>>>> _______________________________________________ mapserver-users
>>>>> mailing list mapserver-users at lists.osgeo.org
>> Frank BRONIEWSKI
>> METRICO s.à r.l.
>> géomètres
>> rue des Romains 36
>> L-5433 NIEDERDONVEN
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
rue des Romains 36
L-5433 NIEDERDONVEN
