[mapserver-users] TYPE/FONT/SIZE breaks labels
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Mon Sep 16 10:09:04 PDT 2013
Add DEBUG 5 into your LAYER and you may see from the MS_ERRORFILE what is the problem. My bet is that you are missing the FONTSET http://www.mapserver.org/mapfile/fontset.html
-Jukka Rahkonen-
Michael McInnis wrote:
> Mapservers!
> I have bailed on dynamically generating labels and fell back to a .map based solution and may have found the primary problem. If I enable TYPE or FONT or SIZE in the LABEL section my map fails to display. I installed Truetype fonts on my Ubuntu system on Friday.
> Does anyone know why the fonts will not function?
LAYER
CONNECTIONTYPE POSTGIS
NAME airports
CONNECTION "host=xxxx dbname=xxxx user=xxxx password=xxxx port=xxxx"
PROCESSING "CLOSE_CONNECTION=DEFER"
#DATA "geom From airports"
DATA "geom From (select a.icao, geom From airports a left join airportdata e on a.icao = e.icao where e.icao Is Not Null) as subquery using unique icao using srid=4326"
STATUS ON
TYPE POINT
LABELITEM "icao"
CLASS
LABEL
#TYPE truetype
#FONT "sans"
#SIZE 8
ANTIALIAS TRUE
POSITION AUTO
PARTIALS TRUE
MINDISTANCE 100
BUFFER 4
COLOR 0 0 0
END
NAME "airportsClass"
STYLE
SYMBOL 'circle-filled'
SIZE 3
COLOR 255 22 22
END
END # Class
END # Layer
