[mapserver-users] MapServer 6.4 Released
andy
andy at squeakycode.net
Tue Sep 24 06:51:20 PDT 2013
Okay. I hadn't seen CUSTOM_PERL_SITESARCH_DIR, so I'll play around with it.
I assume other package maintainers will have the same problem though,
and not just with perl, python looks like it should do the same thing
(unverified).
Is there a redhat or debian package builder here? How'd you handle this?
-Andy
On 9/24/2013 4:51 AM, thomas bonfort wrote:
> Disclaimer: I might have no idea of what I'm talking about given I'm
> no mapscript or perl user or expert.
> I'm a bit weary of applying this one. We'll install to the directory
> required by the current perl installation, which is independent of the
> prefix path. I believe you can supply CUSTOM_PERL_SITEARCH_DIR on the
> command line if you want to install somewhere else, correct?
> thomas
> On 17 September 2013 22:55, andy <andy at squeakycode.net> wrote:
>> On 9/17/2013 3:15 PM, andy wrote:
>>> On 9/17/2013 9:09 AM, thomas bonfort wrote:
>>>> The MapServer team is pleased to announce the release of MapServer
>>>> 6.4, along with the joint release of MapCache 1.2.
>>>> Details of the new features, migration instructions, and download
>>>> links can be found on the dedicated announcement page at
>>>> http://www.mapserver.org/development/announce/6-4.html .
>>>> cheers,
>>>> The MapServer PSC
>>> I start with:
>>> cmake -DCMAKE_INSTALL_PREFIX=/tmp/map -DWITH_PERL=1 ..
>>> it runs ok, and displays:
>>> -- Will install files to /tmp/map
>>> -- Configuring done
>>> -- Generating done
>>> then I run make, which compiles fine. But "make install" has a problem
>>> with mapscript and tries to copy it to /usr/local/lib64, not /tmp/map.
>>> [ 90%] Built target mapserver
>>> [ 90%] Built target legend
>>> [ 91%] Built target mapserv
>>> [ 92%] Built target msencrypt
>>> [ 92%] Built target scalebar
>>> [ 93%] Built target shp2img
>>> [ 94%] Built target shptree
>>> [ 95%] Built target shptreetst
>>> [ 96%] Built target shptreevis
>>> [ 97%] Built target sortshp
>>> [ 98%] Built target tile4ms
>>> [100%] Built target perlmapscript
>>> Install the project...
>>> -- Install configuration: ""
>>> -- Installing: /tmp/map/bin/sortshp
>>> -- Set runtime path of "/tmp/map/bin/sortshp" to
>>> "/tmp/map/lib:/usr/local/pg93/lib:/usr/local/lib"
>>> -- Installing: /tmp/map/bin/shptree
>>> -- Set runtime path of "/tmp/map/bin/shptree" to
>>> -- Installing: /tmp/map/bin/shptreevis
>>> -- Set runtime path of "/tmp/map/bin/shptreevis" to
>>> -- Installing: /tmp/map/bin/msencrypt
>>> -- Set runtime path of "/tmp/map/bin/msencrypt" to
>>> -- Installing: /tmp/map/bin/legend
>>> -- Set runtime path of "/tmp/map/bin/legend" to
>>> -- Installing: /tmp/map/bin/scalebar
>>> -- Set runtime path of "/tmp/map/bin/scalebar" to
>>> -- Installing: /tmp/map/bin/tile4ms
>>> -- Set runtime path of "/tmp/map/bin/tile4ms" to
>>> -- Installing: /tmp/map/bin/shptreetst
>>> -- Set runtime path of "/tmp/map/bin/shptreetst" to
>>> -- Installing: /tmp/map/bin/shp2img
>>> -- Set runtime path of "/tmp/map/bin/shp2img" to
>>> -- Installing: /tmp/map/bin/mapserv
>>> -- Set runtime path of "/tmp/map/bin/mapserv" to
>>> -- Installing: /tmp/map/lib/libmapserver.so.6.4.0
>>> -- Installing: /tmp/map/lib/libmapserver.so.1
>>> -- Set runtime path of "/tmp/map/lib/libmapserver.so.6.4.0" to
>>> -- Installing: /usr/local/lib64/perl5/auto/mapscript/mapscript.so
>>> CMake Error at mapscript/perl/cmake_install.cmake:38 (FILE):
>>> file INSTALL cannot copy file
>>> "/home/andy/gis/mapserver/mapserver-6.4.0/buid/mapscript/perl/mapscript.so"
>>> to "/usr/local/lib64/perl5/auto/mapscript/mapscript.so".
>>> Call Stack (most recent call first):
>>> cmake_install.cmake:273 (INCLUDE)
>>> make: *** [install] Error 1
>>> Any hints how I might fix this?
>>> -Andy
>> In mapscript/perl/CMakeLists.txt, how about stripping the leading '/' so
>> that INSTALL() has a relative path instead of absolute:
>> set(CUSTOM_PERL_SITE_ARCH_DIR ${PERL_SITEARCH} CACHE DIR "Custom
>> installation directory for perl binary extension
>> # strip leading slash so INSTALL() uses CMAKE_INSTALL_PREFIX
>> string(SUBSTRING ${CUSTOM_PERL_SITE_ARCH_DIR} 1 -1
>> CUSTOM_PERL_SITE_ARCH_DIR)
>> Maybe?
>> -Andy
