[mapserver-users] Bad BBOX passed to db query
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Tue Sep 24 10:18:30 PDT 2013
Notice that your Map projection is 4326, but that your Map units are set to meters.
I am guessing that this is your problem.
The map units and the units that the map extent are expressed in have to match your map projection/srs.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jack Walters
Sent: Tuesday, September 24, 2013 11:17 AM
To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Bad BBOX passed to db query
Before Update:
___________________________
MAP
EXTENT -138 40 -110 60
SIZE 500 500
UNITS meters
FONTSET "/var/www/gtc/html/current/mapping/maps/_fonts/fonts.lst"
WEB
METADATA
"wms_title" "Zonar Web Mapping"
"wms_srs" "epsg:4326 epsg:99999 epsg:4269"
"tile_map_edge_buffer" "256" # 16 pixel rendering buffer
"tile_metatile_level" "2" # metatile 2 levels up (4:1 = 1024px metatile)
END #METADATA
END #WEB
TRANSPARENT true
PROJECTION
"init=epsg:4326"
END #PROJECTION
OUTPUTFORMAT
NAME png
DRIVER AGG/PNG
IMAGEMODE RGB
MIMETYPE "image/png"
END
# SYMBOLS
SYMBOL
NAME "misc_circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
SYMBOL
NAME "triangle_circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
SYMBOL
NAME "triangle_arrow"
TYPE vector
FILLED true
POINTS
0 -3
3 6
0 4
-3 6
0 -3
END
END
# LAYERS
LAYER
NAME "loi_names"
DATA "geom FROM ([query]) AS new_table USING UNIQUE id USING SRID=4326"
CONNECTIONTYPE postgis
CONNECTION "user=qa1 dbname=qa1 password=qa1 host=dev-db-001"
TYPE ANNOTATION
STATUS OFF
PROJECTION
"init=epsg:4326"
END #PROJECTION
METADATA
"wms_title" "loi_names"
END #METADATA
LABELITEM "name"
CLASS
LABEL
EXPRESSION ([area] >= 70)
MINSCALEDENOM 36978669.43 # Z#3
MAXSCALEDENOM 295829355.45 # Z#23+
BUFFER 10
FONT VeraBi
SIZE 8
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
OUTLINECOLOR 210 210 210
MINFEATURESIZE 60
END #LABEL
END #CLASS
CLASS
LABEL
EXPRESSION ([area] >= 0.4)
MINSCALEDENOM 9244667.36 # Z#23+
MAXSCALEDENOM 36978669.43 # Z#3
BUFFER 10
FONT VeraBi
SIZE 8
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
MINFEATURESIZE 60
END #LABEL
END #CLASS
CLASS
LABEL
MINSCALEDENOM 0 # Z#23+
MAXSCALEDENOM 9244667.36 # Z#6
BUFFER 10
FONT VeraBi
SIZE 10
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
MINFEATURESIZE 60
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME "loi_polys"
TYPE polygon
STATUS OFF
PROJECTION
"init=epsg:4326"
END #PROJECTION
METADATA
"wms_title" "Locations of Interest polys"
"wms_timeextent" "2000-01-01/2100-01-01"
"wms_timeitem" "ts"
END #METADATA
LABELITEM "name"
CLASS
STYLE
OUTLINECOLOR [rgb_color]
END #STYLE
END #CLASS
END #LAYER
LAYER
NAME "loi_lines"
TYPE line
STATUS OFF
PROJECTION
"init=epsg:4326"
END #PROJECTION
METADATA
"wms_title" "Locations of Interest lines"
"wms_timeitem" "ts"
END #METADATA
LABELITEM "name"
CLASS
STYLE
COLOR [rgb_color]
END #STYLE
END #CLASS
END #LAYER
END #MAP
______________________________________
After Update:
MAP
SIZE 500 500
UNITS meters
WEB
METADATA
END #METADATA
END #WEB
TRANSPARENT true
PROJECTION
AUTO
END #PROJECTION
OUTPUTFORMAT
NAME png
DRIVER AGG/PNG
IMAGEMODE RGB
END
# SYMBOLS
SYMBOL
NAME "misc_circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
SYMBOL
TYPE ellipse
FILLED true
POINTS
1 1
END
END
SYMBOL
TYPE vector
FILLED true
POINTS
0 -3
3 6
0 4
-3 6
0 -3
END
END
# LAYERS
LAYER
NAME "loi_names"
STATUS OFF
TYPE POINT
PROCESSING "CLOSE_CONNECTION=DEFER"
METADATA
END #METADATA
LABELITEM "name"
CLASS
LABEL
BUFFER 10
FONT VeraBi
SIZE 8
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
MINFEATURESIZE 60
END #LABEL
LABEL
BUFFER 10
FONT VeraBi
SIZE 8
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
MINFEATURESIZE 60
END #LABEL
LABEL
BUFFER 10
FONT VeraBi
SIZE 10
TYPE truetype
WRAP "/"
COLOR [rgb_color]
OUTLINEWIDTH 2
MINFEATURESIZE 60
END #LABEL
END #CLASS
END #LAYER
LAYER
NAME "loi_polys"
DEBUG 1
STATUS OFF
TYPE POLYGON
LABELITEM "name"
METADATA
"wms_title" "loi_polys"
END #METADATA
CLASS
STYLE
END #STYLE
END #CLASS
END #LAYER
LAYER
NAME "loi_lines"
STATUS OFF
TYPE LINE
LABELITEM "name"
METADATA
"wms_title" "loi_lines"
END #METADATA
CLASS
STYLE
COLOR [rgb_color]
END #STYLE
END #CLASS
END #LAYER
END #MAP
Hope that helps.
Thanks,
Jack Walters
Web Development Engineer III
Zonar Systems
Confidentiality Notice: This e-mail may contain proprietary information some of which may be legally privileged. It is for the intended recipient(s) only. If you believe that it has been sent to you in error, please notify the sender by reply e-mail and delete the message. Any disclosure, copying, distribution or use of this information by someone other than the intended recipient(s) is prohibited and may be unlawful.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
