[mapserver-users] GEOMTRANSFORM definition causing an error
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Thu Sep 26 10:44:29 PDT 2013
I have no idea why you are getting an error about jquery, but is does look like you might be trying to apply a 150 degree buffer around your feature...
I don't know what version you are using, but from this RFC, it appears as though LAYER-level geomtransforms use ground coordinates: http://mapserver.org/development/rfc/ms-rfc-89.html
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of tday
Sent: Thursday, September 26, 2013 12:21 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] GEOMTRANSFORM definition causing an error
Hello,
I'm trying to implement a buffer layer using layer GEOMTRANSFORM. I am adding this line to the second LAYER definition in the following map file:
GEOMTRANSFORM (buffer([shape], 150))
After adding this line, Mapserver throws an error:
Mapserver response:undefined - Status:error - Error:[Exception... "Failure"
nsresult: "0x80004005 (NS_ERROR_FAILURE)" location: "JS frame ::
http://[domain obscured]/assets/a4f84659/jquery.js :: .send :: line 8102"
data: no]
The second layer is exactly the same as the first layer except for the GEOMTRANSFORM definition.
Any ideas what the problem may be? Thanks!
MAP
NAME "obscured"
STATUS ON
SIZE 912 380
EXTENT -180 -90 180 90
UNITS FEET
IMAGECOLOR 255 255 255
FONTSET /web/mapserver/fonts.list
CONFIG MS_ERRORFILE stdout
# CONFIG MS_ERRORFILE /web/mapserver/ms_error.txt
DEBUG 5
OUTPUTFORMAT
NAME "json"
DRIVER "TEMPLATE"
#MIMETYPE "application/json; subtype=geojson"
FORMATOPTION "FILE=geojson.tmpl"
END
OUTPUTFORMAT
NAME "geojson"
DRIVER "TEMPLATE"
END
# Web Interface
WEB
IMAGEPATH "../out/"
IMAGEURL "/out/"
METADATA
# obscured
END
END
PROJECTION
"init=epsg:4269"
END
# Layers
# Parcels
LAYER
NAME "parcels"
METADATA
"wfs_title" "Parcels"
"wfs_srs" "EPSG:4269"
"gml_include_items" "all"
"gml_featureid" "OBJECTID"
"wfs_enable_request" "*"
"wfs_getfeature_formatlist" "gml,json,geojson"
"gml_COUNTRY_ID_type" "Character"
"gml_STATE_ID_type" "Character"
"gml_COUNTY_ID_type" "Character"
"gml_PARCEL_ID_type" "Character"
END
TYPE POLYGON
STATUS ON
CONNECTIONTYPE oraclespatial
CONNECTION "SDE/3nz0rb4rr4g1n at ArcSDE"
DATA "SHAPE FROM (select OBJECTID, COUNTRY_ID, STATE_ID,
COUNTY_ID, PARCEL_ID, APP_USER_G, SHAPE from PARCEL) USING FILTER"
PROJECTION
"init=epsg:4269"
END
# TOLERANCEUNITS feet
# TOLERANCE 150
CLASS
NAME "Parcels"
STYLE
COLOR 240 240 240
OUTLINECOLOR 0 0 0
END
END
END
# Buffered Parcels
LAYER
NAME "parcelbuffers"
METADATA
"wfs_title" "Parcel Buffers"
END
TYPE POLYGON
STATUS ON
PROJECTION
"init=epsg:4269"
END
# GEOMTRANSFORM (buffer([shape], 150))
CLASS
NAME "Parcel Buffers"
STYLE
COLOR 240 240 240
OUTLINECOLOR 0 0 0
END
END
END
END
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEOMTRANSFORM-definition-causing-an-error-tp5080269.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
