[mapserver-users] GEOMTRANSFORM definition causing an error
tday
tday at notionslate.net
Fri Sep 27 06:16:23 PDT 2013
Changing to:
GEOMTRANSFORM (buffer([shape], 0.0)
...has the same error result.
There are a total of 5 mapserver calls to load the web page (I'm using
leaflet in the browser). The error occurs on the very first call to
mapserver from an ajax request which is requesting the un-buffered parcel
layer (not the one with the GEOMTRANFORM option). The GET request URL is:
http://wfsd.visualapms.com/wfs.php?SERVICE=WFS&VERSION=1.1.0&REQUEST=getfeature&TYPENAME=parcels&SRSNAME=EPSG:4269&OUTPUTFORMAT=json&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EPARCEL_ID%3C/PropertyName%3E%3CLiteral%3E700008517%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E
...and this is returned to the browser...
"NetworkError: 500 Internal Server Error -
http://wfsd.visualapms.com/wfs.php?SERVICE=WFS&VERSION=1.1.0&REQUEST=getfeature&TYPENAME=parcels&SRSNAME=EPSG:4269&OUTPUTFORMAT=json&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EPARCEL_ID%3C/PropertyName%3E%3CLiteral%3E700008517%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E"
You could test the url yourself.
When debugging the ajax response, the 8102 is the line number in jQuery
1.7.1 core. Not sure why jquery is coughing there, but the request object
and error are returned to the ajax error function.
I have not used shp2img before, I'll need to research to give you an answer
for that.
I'll see if I can get the data in shapefile format which will require some
work with the server admin.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEOMTRANSFORM-definition-causing-an-error-tp5080269p5080554.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
