[mapserver-users] GEOMTRANSFORM definition causing an error
Stephen Woodbridge woodbri at swoodbridge.com
Fri Sep 27 06:50:36 PDT 2013
On 9/27/2013 9:16 AM, tday wrote:
> Changing to:
> GEOMTRANSFORM (buffer([shape], 0.0)
> ...has the same error result.
> There are a total of 5 mapserver calls to load the web page (I'm using
> leaflet in the browser). The error occurs on the very first call to
> mapserver from an ajax request which is requesting the un-buffered parcel
> layer (not the one with the GEOMTRANFORM option). The GET request URL is:
> http://wfsd.visualapms.com/wfs.php?SERVICE=WFS&VERSION=1.1.0&REQUEST=getfeature&TYPENAME=parcels&SRSNAME=EPSG:4269&OUTPUTFORMAT=json&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EPARCEL_ID%3C/PropertyName%3E%3CLiteral%3E700008517%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E
This is actually calling a PHP script, so you might need to look at this
to figure out what is actually getting passed to mapserver or if this is
a mapscript program in which case you may need to debug that to see what
is happening. It might just be hiding the mapfile parameter.
> ...and this is returned to the browser...
> "NetworkError: 500 Internal Server Error -
> http://wfsd.visualapms.com/wfs.php?SERVICE=WFS&VERSION=1.1.0&REQUEST=getfeature&TYPENAME=parcels&SRSNAME=EPSG:4269&OUTPUTFORMAT=json&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EPARCEL_ID%3C/PropertyName%3E%3CLiteral%3E700008517%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E"
> You could test the url yourself.
I get no response back from the above URL which might be interpreted as
a timeout and hence a server error.
> When debugging the ajax response, the 8102 is the line number in jQuery
> 1.7.1 core. Not sure why jquery is coughing there, but the request object
> and error are returned to the ajax error function.
> I have not used shp2img before, I'll need to research to give you an answer
> for that.
Ok it might be easier to do this:
/pat/to/mapserv
QUERY_STRING='map=/path/to/mapfile.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=getfeature&TYPENAME=parcels&SRSNAME=EPSG:4269&OUTPUTFORMAT=json&FILTER=%3CFilter%3E%3CPropertyIsEqualTo%3E%3CPropertyName%3EPARCEL_ID%3C/PropertyName%3E%3CLiteral%3E700008517%3C/Literal%3E%3C/PropertyIsEqualTo%3E%3C/Filter%3E'
and see what this reports.
-Steve W
> I'll see if I can get the data in shapefile format which will require some
> work with the server admin.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/GEOMTRANSFORM-definition-causing-an-error-tp5080269p5080554.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
