[mapserver-users] How to hide the "?map=servemap.map" from URL under IIS
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Tue Apr 1 10:33:35 PDT 2014
Tamas,
I just verified that the url rewrites in the web.config don't work unless
you actually install the rewrite module.
James
-----Original Message-----
Sent: Sunday, March 30, 2014 8:02 AM
To: Tamas Szekeres
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] How to hide the "?map=servemap.map" from URL
under IIS
Hi Tamas,
I was able to get it working. Thanks! I'm not sure if I had to, but I
installed the IIS 7 rewrite module, which doesn't come with IIS 7 by
default, then was able to apply the following rewrite rule:
<configuration>
<system.webServer>
<rewrite>
<rules>
<rule name="Rewrite radeswms to mapserv.exe">
<match url="mapserver/radeswms" />
<action type="Rewrite"
url="mapserver/mapserv.exe?map=content/servemap.map" />
</rule>
</rules>
</rewrite>
</system.webServer>
</configuration>
This is saved in the web.config in wwwroot directory.
Thanks,
James
Sent: Friday, March 28, 2014 5:54 AM
To: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
Subject: Re: [mapserver-users] How to hide the "?map=servemap.map" from URL
under IIS
James,
You may probably look into something like this:
http://stackoverflow.com/questions/3071936/getting-iis7-to-rewite-but-still-
pass-querystring-parameters
Best regards,
Tamas
2014-03-28 7:55 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
<james.evans.4 at us.af.mil>:
Can anyone point out the right way to alias my mapserver URL under
IIS 7? I'm not seeing it.
Thanks,
James
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140401/407d40cf/attachment.bin>
